My 2000 Taurus drivers window works intermittently. I replaced the upper right relay in the I/P Fuse Block w/ limited result. However, I found that when the drivers window doesn't work, I can jiggle the same relay to get it to operate. Should I consider replacing the Fuse Block? And if so, is this something I could do w/ ordinary shop tools?
Can you disconnect the battery and bend in the female receiving prongs with a small screwdriver a bit to snug it up? Iirc, one member wedged a wooden toothpick or matchstick to tighten the elec. conn.
