1 - 2 of 2 Posts
I have a 2000 SE 3.0 AX4N - It shifts great into 1st,2nd,3rd but Overdrive never kicks in. I changed the TRS (Transmission Range Sensor) from a Junk Yard Car but NO diffrence. I believe the Trans is a little too newer for the Retainer Clip TSB. It drives like a normal "3speed" trans. The Trans light blinks if I keep it in OD too long with the cruise control on.
My question is : Can't I just swap out the Valve Body to fix this problem? I mean the selonoids and retainer clip and all that crap is on the valve body, OR "any" other helpful information would be apreciated.
what codes did you get when you scanned it?
Some trannie shops will do a free non teardown diagnosis if you play dumb to them.
bob
1 - 2 of 2 Posts
