1 - 9 of 9 Posts
Where's a good place to jack up using a floor jack on a 1999 Taurus. I can see the sub frame about 10 inches inside of the factory jack points. Would that be Ok? I would like to lift the front or rear end so both front or rear wheels are in air at the same time.
Thanks
Madison
^^^^^ Same here.
Those locations are OK if you use a good floor jack. Issue is where do you put the jackstands which are needed for safety. Front location I use are the heavy unibody attachment points for the subframe but rear is a bit more of an issue. It depends on your body condition because of corrosion.
what ever you do,
DO NOT jack up a high mileage older taurus on the unibody sides.
front subframe is fine
i put a couple of wood scraps on my floor jack in the rear and jack the
bumper when the support attaches to it.
I fixed mine as I expect to jack up one at a time for brakes, tire rotation and such. 1/8" X 3" stock from Lowes works just fine. Pays to inspect them before then crumple like I did.
In the front I always jack under the subframe. If I place the floor jack right under the rear subframe bolt then I've got room to place the jack stand right in front of it.
1 - 9 of 9 Posts
