1999 DOHC Se. I will be doing a front brake job on my son's car this weekend. Had put new pads and rotors about a year ago and they are totally gone. When it was in the shop for another issue, they said the brakes were dragging. I took it home and checked and did not see anything and the brakes were not that hot. Took to a different shop and they saidthey could not find any evidence either. Anyway, they wore down fast and gas mileage is terrible, so I must have some kind of intermittant brake drag issue. I am going to change rotors, pads, calipers, and caliper hoses this weekend. I am also going to change th fluid as best I can. Any suggestions on pretty good pads. I will be going to autozone. I have a credit built up I want to use. The old pads were cheap and made a lot of dust. This should take care of any drag issues unless the master cylinder is bad. The glide pins were greased up on the last brake change, anything elseto cause the brakes to drag?
