I had this car at a very reputable shop. Bank 1 and 2 reporting lean on OBDll codes.They changed all the hoses, removed the intake manifold, changed plugs. The O2 sensors were very weak on the scope. Changed them out. Afterwards, the signals were very strong. I am an electronic technician, and the mechanic showed me everything. Put back together, I drove the car and in less than a day the same codes came back. They sprayed cleaner on the box that the PVC valve connects too, it has a crack in it. The part number is XW4Z-6A785-BA A Ford part number. That piece is no longer available. My 1998 Taurus Comfort SE only has 168K miles on it. The car runs great, but I can tell that the computer is dumping all the fuel it can as gas mileage has gone down a bit, but the car still runs great. The mechanic does not now what to do. They cannot find this part, and neither can I anywhere.
We have isolated the problem down to this part. It irks me that it is "0" degrees outside, and I cannot work on this car now. Motor vehicle will no renew the Registration until the engine service light is off. If it was spring, I could remove XW4Z-6A785-BA and coat it swith High Temperature Steel Epoxy, and try and cure the leak, or make a plate and run a in line PVC valve, I have a small machine shop, maybe even fix that part. Does anyone know where I may be able to find the air fuel separator box for a 1998 Duratec Taurus (Part # XW4Z-6A785-BA)? There is a part "# XW4Z-6A785-BE" that looks the same, but there is no way of knowing if that would work. Does anyone know of a fix, or ann alternative to this fuel oil separator that would work. I am desperate. This was my Mom's car, who passed away 5 months ago. This car has so much sentimental value to me, besides being an excellent automobile, I have to come up with something. I am even thinking of running a can, like a race car. That means having paid for the work for nothing, I had the front axles changed, dropped the fuel tank and replaced the fuel pump, new brakes all the way around. Inner outer tie rod ends replaced, new ball joints. This car runs super amazing, and handles so much better. For such a little part, that should have been made out of metal, to cause me to possible render the car not able to renew the registration ludicrous, but then, Connecticut is the ludicrous state. The diagnosis is not in question as every part in the system has been changed, and a little squirt of fluid on the box instantly causes the OBDll to read Lean Bank 1 and ll, you can see the O2 sensors flatten right out on the O'scope function of the reader.
Desperate for help!! I am open to any suggestions. Thank You.
Ford Part# XW4Z-6A785-BA needed............Will Ford Part Number XW4Z-6A785-BE which looks the same work? Does anyone know?
