1 - 11 of 11 Posts
Hi All,
New to the forum so please forgive (and correct) if I'm not following proper protocol. I have a 1998 Ford Taurus SE 3.0L V6 EFI; it runs great, no real issues starting no rough idle. I've recently changed the O2 sensors and the crank and camshaft sensors. I'm getting the P0340 (Camshaft Position Sensor A Circuit Bank 1 or Single Sensor) and P1309 (Misfire Mon Hdwr-CMP Misaligned, CKP/CMP Noise, PCM AICE Chip). I have no issues driving, starting or running. My smog extension is up next Tuesday and I can't get it done because of the "Check Engine Soon" light. Any help would be greatly appreciated, I love this car, it was a gift from my Uncle who has since passed and I'd love to keep it running as long as possible.
Just replacing the CMP sensor at the top of the synchronizer cannot lead to a misalignment. If you replaced the whole synchronizer then perhaps the synchronizer is one tooth off.
Why did you replace those sensors? Was this problem apparent before that?
I had the check engine light come on just before smog was due. I changed the O2 Sensors and the other codes listed a few things to do; two of which were the cam/crankshaft sensor. I'm worried that it's the cable harness...I'm not very good with electrical.
I don't see a sensor at the top and I cant find a good engine schematic for my car. I changes the sensors on the left (passenger) side of the engine; cam on top and crank down below. Do you have any idea where I can find good drawing for my car?
^+1. No cam sync on the tec. CMP sensor is on the pass. end of the front bank (#2). CKP sensor is down near the crank pulley.
1 - 11 of 11 Posts
