Just fixed my 1998 Ford Taurus SE- Had to replace the Pump Shaft for the Trans. Now, while test dirving her to make sure gears shifted smoothly, I noticed their is some "flutering" with the car. It happens randomly. Happens while in Drive/ Over-Drive/ Park. She will feel like she wants to accelrate for about half a second to a second then return to normal. This happen for about 30-45 seconds then she will clear out for about 2-3 min then right back to the flutering. It will stop if I step into her kinda to clear her throat. I believe this may have a direct connection with the IAC Valve or maybe a small vaccum leak. Any thoughts would be greatly appricated.
1998 Ford Taurus SE- 3.0L- AX4N Trans. Also, what would be the best way to clean the IAC? What could pottentially happen if the problem is not addresses ASAP? Thanks again for everything and I look forward to a solution.
By fluttering speed do you mean just RPM ramping up and down or the car is physically moving faster then slower?
Mostly feels like the RPM's. However, the whole car feels like the RPM's are trying to push it and then back off. I can watch the RPM guage jump ever so slighly maybe 25-50 RPM's if that. I mean but the actual speed does incrase/decrease. As long as I keep my foot constant, the speed will stay the same, it's just feels like RPM's
On my Cougar with o/d it used to do that until I did a fluid flush.
It was o/d engaging and disengaging randomly.
It could be a loose vacuum line in your case.
Not sure if a bad TPS could cause that.
Shouldn't be Trans. Fluid or anything like that. Just put in 12 Quarts of Malchum 5 Tranny Fluid as well as Tranny In A Can (To Keep Seal's in good condition)- Everything that I've seen is it could be the a Vaccum Leak going to the Manifold. Now it;s just a matter of figuring out which hose is the culprit.
