i have a 98 sable ax4n ohv the transmission you can take off and it will shift fine through all the gears until you stop or slow below 5 mph then it goes to neutral . you then have to put it in reverse and back to drive to go again. it does the same if you dont go anywhere just put into drive hold foot on brake after about 20 30 seconds drops out of drive to neutral. go to reverse and back to drive and it will repeat the same thing. anybody have this problem before? any replies would be appreciated
