almost instantly or within a few seconds.Clogged Catalytic Converter or exhaust restriction? You can pull a O2 Sensor or two to test or use a vacuum gauge if it runs long enough. how long does it run before dying?
yes. I will check what the codes are.Any light or codes?
ok i will try that!IAC stuck/bad. Hold throttle slightly open while starting it.
