Can anyone help i have my driver's side caliper brace rubbing againt my rotor mainly when i turn i just put new calipers,rotors and pads on the car 6 months ago and it has fine i then had new lower ball joints put on and a week later it started so i figured maybe it was my wheel bearings so i replaced them today and still having the same problem it is only happening on the drivers side front on the wheel side of the rotor (the side you can see) anyone have any idea what might be causing this ??? thanks in advance
Discussion Starter · #2 ·
96 taurus
does this sound like a bent CV Halfshaft ???? the rim rotor all wobble just by touching it and i put a new wheel bearing on yesturday ????
Did you check the condition of the slider pins when you changed the caliper?
