1 - 1 of 1 Posts
1995 Ford Taurus wagon, 3.0 showing a 3 then 4 flash on airbag just started recently (Code 34 (triple flash, pause, four flashes) means the driver side airbag has a shorted circuit or one with low resistance) but I noticed the ignition switch is really sloppy. Could the sloppy ignition switch be causing the fault? I can turn the car off and back on and it will stop flashing.
1 - 1 of 1 Posts
