1 - 2 of 2 Posts
My 94 3.0 tranny makes some noises when in gear. I have noticed when the car is running at normal temperature there is a slight rattle noise that comes from the tranny. The noise disappears as soon as I put the gear into neutral or park. The tranny is shifting smooth and is not giving any problems. It has had its filter changed with mercon V oil earlier this year. Car has 71,000 miles.
What do you guys think?
Since it only does it when its hot do you think a aftermarket transmission cooler would fix it?
Has anyone ever installed one on a 1994 body style?
Any pics if so?
Confused and hopeless :noes:
Did the noise begin after the tranny service, or was it there beforehand????
Was the OEM Motorcraft/Filtran tranny filter used & was a full tranny fluid pumpout/fluid exchange done????
Have you checked the tranny fluid level????
1 - 2 of 2 Posts
