I have a 1994 SHO recently had to replace the water pump. while doing that i replaced the thermostat(192dgr) too. Ever since then the cars low coolant light lights up every 50 miles or so.
There is no sign of a leak any idea what could be wrong?
Thanks
-Pat
yes, most likely a head gasket
do a couple checks, like sweet smelling exhaust, white smoke out of the exhaust, bubbles in your radiator (remove cap and start engine, rev)
use a block tester
before i forget i more thing to check. fill up the coolant and idle till hot. look at the radiator ( hoses and other things too ) for a little stream of fluid or steam. shut the engine off and look again
