Hi my 1994 ford Taurus wagon cranks fine but doesn't start
So far I've replaced the spark plugs, cap rotor ignition module, engine ,transmission ,battery and just drove the car 6100 miles from Arizona to the east coast and got 27mpg ...I have basically restored the car....when it does run it runs like a new car but intermittently I am at my wits end and I love my Taurus (since I have owned 7 Taurus's Wagons) in the future I want 2 find a 1986 mt5 wagon for a spare car...
HELP!!!!!!!!!!!!!!! I hate walking the Engine is a 3.8L
Randy Lee Munro (480)703-3961
0
Ford had lots of problems with their ignition switches from the early 80s until the mid 90s. Pull the sttring column trin, and have a look at the switch and its connector. Look for melted plastic, corroded, damaged contacts, etc. Might want to just replace it, as it is easy and cheap.
Is the fuel pump original? Can you hear it run for a second or 2 when the key is turned to run? Next time you get a crank no start check fuel pressure and check for spark. It is missing one of the 2.
I just replaced the ignition switch
I just replaced the ignition switch and fuel filter and starter
still no start but cranks fine
I just burped the fuel rail and its running again
So I guess its time to replace the fuel pump assy
Which fuel pump is best????
About this Discussion
4 Participants
jag1959
Full Forum Listing
