I have a 1993 Mercury Sable GS and it has about 92,000 miles on it. It sat for approx 2 years when my grandmother passed away. When I took posession of it 3 years ago I noticed a loud hum when driving coming from the rear. To me it sounded like bad wheel bearings but I can not find anything on here about the car even having rear wheel bearings. The hum is still there and drives fine. Its just loud and annoying. I have drum brakes in the rear if that helps.
Wheel Bearing
It has rear wheel bearings and I believe it is old enough to have replaceable tapered rollers. Unlikely to fail unless it has been in water. Tires can make a similar sound.
turns out that the hum is the goodyear aquatred 3 tires. I moved them to the front and now the hum is there. Unreal that a tire can be manufactured to be noisy! There's less than 10,000 on them.
If they are directional tires and they are put in the wrong direction they can hum as well. I had that happen on an old car that I bought. Turned the tires the right direction and no more hum.
