<-----------Scroll down for the pictures------------>
As the topic states, I'm selling Vanessa, since I'm getting... something else.
Click on the link in my sig for the pictures.
She has:
[ ---> denotes something I forgot to add in the beginning. ]
145,000 miles on the odometer
1995 Police 3.8L Engine w/77,000 miles
New Head gaskets
New rod bearings (Installed 1/17/2004)
New heater core.
New Radiator.
New power steering return line.
4 new Kumho Ecsta HP4 tires on police rims
New mufflers, and rear Y-pipe
Less than 10,000 miles on new carbon metallic pads and new rotors.
Anonda Motorsports SFC's
---> STOCK 24mm/26mm sway bars.
Crystalline headlamps from 1995 Taurus SE
---> 4 wheel disc ABS
---> 130A alternator
---> Factory dual exhaust
---> High current wiring already in passenger compartment
Blue LED illuminated instrumentation
Blue LED maplights
Alpine Type-S Front 6.5" Speakers and Type-S 5x7" rear speakers
Alpine CDA-7893 240W (60w x 4) CD Headunit
She does/ needs:
Rear strut mounts. The struts themselves are fine.
Passenger sway link, tho I'll probably replace this soon enough.
A/C Compressor and pressure line. Everything else in the system is intact.
Trunk lid needs to be repainted, due to paint adhesion problems (big surprise there <_< )
Transmission leaks in hot weather, as well as it was beginning to slip. Stopped once winter set in.
I want:
$1300 for her with the Alpine, or $1100 without the Alpine.
This is an extremely short list, since I'm headed out right now. I'm sure I'll be updating it later on tonight when I get home, so post or PM or e-mail me any questions you may have about her. If you want my phone number, I'll PM it to you.
Later.
~Hamal
*edit*
New Items added to list above also. Look for the --->
New starter.
New upper and lower radiator hoses.
New thermostat when head gaskets were done.
Oil pan resealed when rod bearings were installed.
Rear passenger caliper is new.
Rear passenger brake hose is new.
Plugs, wires, and ignition coil are all less than 2 months old.
Mileage is now 146,600 after the trip to RI.
I'm also including a GM Strut Tower Brace. It's up to you if you choose to install it or not.
And to clarify:
With/ without the Alpine only applies to the headunit. If it's sold without the Alpine headunit, I'll put the factory headunit back in. I'm leaving the Alpine speakers in regardless after the sale. Lucky you.
She has:
New Head gaskets
New heater core.
New Radiator.
Blue LED maplights
She does/ needs:
I want:
Later.
~Hamal
*edit*
New starter.
And to clarify:
