1 - 11 of 11 Posts
Hi I have a 2011 Taurus Sel with 310xxx miles and a blown head gasket. I’m looking to just replacing the entire engine rather than rebuilding it. I have found a lot of 13’ model year engines and beer of the 3.5 and was wondering if that would work in my 2011? Any thoughts if that’s a possibility without our too much tweaking? Thanks
Bigger hassle than it's worth. 2013+ is when they went to TiVCT and made other changes.
Hey, nothing is impossible. I'm sure it would fit, but the electrical architecture and the module network would probably get really upset. I'd recommend sticking with a 3.5 from the 2010-2012 years.
Ok that’s what I was figuring. Thanks for the responses! Just gonna look for an engine between those years. I’ve heard a lot of bad things about the water pumps going out often on these. What’s the mileage I should be aware of when getting an engine. Probably best just to change out the pump while I have the engine out of the car
Find the lowest mileage engine you can find, and still change out the water Pump. I think around the 85k miles + is the time the pump could fail or maybe a little later (mileage wise). Either way may as well change out the pump whilst the engine swap is being done.
So just out of curiosity, is the water pump something that WILL fail/leak or something that fails more often than not in these vehicles and a lot of us will actually be fine? Because after looking up how to replace it thinking it was easy, my anxiety rose at an alarming rate as I witnessed the engine being removed from the car and the timing components being removed to access the pump. Please Lord tell me my car will not nuke it's own coolant pump.
Well I had a 2010 SHO with over 110k miles and had no issues with the water pump and so far my 13 is ok with 84k miles and all is good. It's not something that WILL fail, however if it does it can be catastrophic and if not caught in time it will mean a new engine. There are few users on here who have unfortunately suffered water pump failure.
My dealership quoted me $1300 for the replacement (that was with a little discount too). I was just curious, there is a user on here who did the job himself and he said it's a big job for sure. Damn internal water pumps....a la Chrysler 2.7's!
Yeah it's not something I think I could tackle. I'm nearing 81k with no issues that I know of. At that point if the engine is out of the car, I'll just force a 5.0 or a 5.2 voodoo in the car like I've always dreamed of doing (I'm not kidding). Are there any signs or symptoms of pump failure to watch out for to tell whether or not it's time?
With the pump being internal, rarely will you see any drops of coolant etc.as it leaks internally. However you may have loss of heat and car temp creeping up. If that happens I'd stop the car right there and get it towed so's not to cause engine failure. You can have your oil analysed too to see if their is any contamination (such as coolant) I believe
I did request a kit from a US company to obtain oil samples for them to test months back, but never received it (free). I will need to follow up with them.
The water pump failing is an issue, but it is not as bad of an issue as people are making it out to be. As long as you change the coolant at the recommended intervals, you are generally fine. Also, the only time you hear about these issue is when they actually fail. There are plenty of owners out there who do not have this issue even after 200k miles. From what I have been told, it is the coolant becoming acidic and causing the pump to fail. Just change the coolant and you are fine. Also you normally hear about these issue when people beat the hell out of the car, do minimal maintenance and then complain the car is crap. Not saying everyone who has had this issue is that way, but a lot of people are.
1 - 11 of 11 Posts
