Hello,
I just replaced the suspension on all 4 corners with KYB Strut + Assemblies and am now looking at the rear sway bar issue :D. Front SB is still stock.
I can't find the part new in the great white north but can source a used piece (OEM 19mm?) but it's pricey.
I'm not too interested in replacing the front SB, will a 23mm rear Sway Bar work out OK or will it introduce negative ride effects? Personal experiences appreciated.
Anyone from Canada order via SHO Source and was it a smooth transaction (ie no Customs surprises)?
TIA
The 23mm does a good job tightening up the rear without making it too tail happy. You will like it.
Many thanks again to the FORUM.
I've just had the SHO swaybar/endlinks/bushings installed.
WOW, what a difference. Much tighter driving dynamics:)
Highly recommended for the post 2004 1/2 generation.
