Hi,
Trying to fix my mother in law's 05 Vuclan Taurus.
Syptoms: P0300 and P0316, also seems to crank too much when starting hot or cold - starting seems weak initially (like the cranking pauses, then cranks normal) Battery and starter seem ok.
Last year I fixed some codes by replacing plugs and wires (using recommended parts)
I read that the crankshaft position sensor (CKP) is a likely cuplrit, so I replaced that last week - no change.
Any other suggestions? I know there's a vaccuum leak issue with a seal but I checked that earlier and it seemed ok.
thanks for any suggestions.
