1 - 13 of 13 Posts
I am currently battling a lean condition on my car, but also wanted to take a stab at it and replace my O2 sensors, considering I'm @ 97k and I think it may be time for replacement anyway. I was searching RockAuto and they have a bunch of options and various manufacturers... Which one(s) do I need to order for my non-FFV Vulcan?
I've used a Bosch in the past and they seem ok.
[attachmentid=28462]
[attachmentid=28463]
The beck arnley number 1654300 will replace the one in the very front but I am not sure about the one in front of the firewall. I cant tell whether or not the back one is mounted before or after the catalytic converter.
A side note...... Be sure to check the group buy/vendor section for a 5% discount code if you are buying from Rock auto.
Bosch is also good, but I would check prices at Autozone and Advance auto parts before buying, if they have those there.
I looked up the correct parts numbers off teh Bosch website. Best price was online from RockAuto including the shipping costs
I have a few short questions about o2 sensors.
Are there only 2?
Which is the upstream and which is the downstream?
I know the the one in the front is pre catalytic converter, so is the one in the back post converter?
Are there only 2?
4 total - 2 pre-cat 2-post cat
- someone correct me if I'm wrong
you have lean codes for both banks? if so thats not going to fix it.
I'm doing it as preventative maintenance since I will have the plenum off to replace the EGR, DPFE and check the vacuum lines on the firewall and surrounding areas.
<div class='quotemain'>
On the lean condition, be sure to check the PCV valve & it's rubber plumbing, as they are often the cause of vacuum leaks that cause lean codes.
Probably a good idea to replace the O2 sensors with 95K on them.
I just replaced the 94 Taurus 3.8L O2 sensors in Nov, with Bosch from Advance Auto & they seem to be doing ok so far. Harness length & plug type were OEM & plugged right in.
Even came with antisieze compound already on the sensors threads.
Actually took longer to get the parts & tools together & put the car up on ramps, than it did to change the O2 sensors out.
I used Advance Autos "loan-a-tool" split O2 sensor socket set to remove the old sensors & install & torque the new ones in. It's worth the time to stop by & pick it up, as the rear O2 sensor was a little tight on space & the kits off set socket came in handy.
More thoughts for consideration.
Can some one distinguish between upstream and down stream and which is the one behind the intake manifold. Also is that one pre or post cat?
Discussion Starter #11
Upstream = pre-cat
Downstream = post-cat
You don't need the post cat ones unless you get cat efficiency codes.
I would get the Motorcraft ones.
1 - 13 of 13 Posts
