1 - 13 of 13 Posts
Long story I had to replace a lot on this car, trans gasket was one of them. Roughly calculated a 2 quart loss (no full service, just gasket) and am wondering about what it did today. Went to drive it and had to turn around due to alternator clip refusing to actually go on and as I pulled up I noticed a pool of fluid and the trail marks where I backed it up. I got underneath it and ran it to operating temperature but no leak. It looks like it came out of the filler neck and dripped down as well as get on some of the wire loom. My question is, assuming that's where it came from, what would cause that? I haven't really heard about that happening or seen it before so I'm curious how overfilled it would have to be to do that? Or is there another culprit?
" ineffective" Nope. Very effective in spilling fluid. Not one of Ford's better ideas. My Sable wagon bought used had no cap. The nipple was very dirty. I got a cap from the JY and cleaned it up, cleaned the nipple and put it on right. No issues. Best remove the intake plenum for putting it on. Then check the filter while in there.
Have a nice Independence Day.
Ineffective as a vent, effective as a fluid mess. If they wanted it to work all the time, they would have used what they did on my Lincoln Cont. Hard plastic non removable. That works.
The vent is an "inverted bucket design". It is the plan that it will shed water from the top, and keep temporary flooding of water out.
On rear wheel drives and likely 4 wheel the gear case uses a one way valve/bucket. It lets air our but not back in resulting in no pressure to some vacuum in the gear case. That keeps the seals from leaking. I had '80 Zephyr that kept leaking seals. My brother who was a life long diesel mechanic told me the thing they had to do on routine maintenance was to wiggle the vent cap as they can stick shut. I checked mine and it was stuck. Easy fix. I had replaced the axle seals but they leaked. Vent fixed leaks.
The Bull vent is in a awkward place so removal of the inlet plenum makes it easy to check.
So Ford had a bulletin on this. But simple fix for me, just clean and put it back the correct way.
Thanks for all the replies guys, the venting part makes sense however I am a little bit unsure about the nipple and stuff you all are talking about. By little bit I mean I have no idea what you all are talking about, is there anyway you guys could educate me on what that is. Not being a smart ass or sarcastic, I really have no clue.
Pull the vent cap off, then push it on flush, then pull it back up 1 click/notch.
I feel dumb asking but where is the vent cap located on that car, I do all my work in my parking lot so it's hard for me to get a super clear view.
Dunno on your '04, but on my gen3 tecs ('98/'99) it was right under the corrugated air hose/tube/snorkel. Didn't have to remove anything to access it.
Discussion Starter #11
Ill check that out here shortly, I just have a hard time believing it's anything major because the fluid came out but quit. It just dawned on me which corrugated line you're talking about, it's on the backside of the transmission near the fill neck
1 - 13 of 13 Posts
