I recently bought a set of Jag wheels for my mom's 04 Sable. They have the same bolt pattern and they fit, but I didn't even think about the wheels being wider than the Mercury wheels (absolutely stupid move - I know!!), but I was just wondering if anyone had done this before... I already had them mounted on her Blizzak tires, and I've been trying to find spacers.
Does anyone know of anywhere to get spacers for this?
Thanks in advance.
how much space do you need?
25mm right here..
Eibach 90.4.25.010.3 - Eibach Pro Spacer Kits - Overview - SummitRacing.com
You want the minimal amount of spacing without rubbing. 25mm may be too much. I have no idea the wheel dimensions. Offset can be a killer too. if the wheel is wider and the offset different than stock you may or may not rub. Thats why you should always check the dimensions.
