So my drover side door does not turn on the overhead lights or ding when I open it the pass side does turn on the lights tho and all the buttons work on both doors what would cause this
Thanks
Many topics that cover this. Spray a penetrating fluid in the door latch and open and close the door several times. This should free up the switch inside. Then spray a lube inside to keep it freed.
So I tried some wd40 and that did nothing light still stays off I do not have the door ajar light but the window and lock switches stay on all the time should I just try some diferent lube or could it be zomthing else
