Had a left front wheel bearing changed in March. In April had a left front spring break, both sides got new brakes, shocks and struts. There is a klunking noise that can be felt on the left side front.
2 weeks ago had the ball joints replaced, still there. Last week had new axel and replacement bearing and replacement struts, no change.
The sound happens at any speed when you hit a bump. Most noticeably when driving in a parking lot at a slow speed.
Any ideas on what to look for next would be helpful - out of ideas.
Thanks all.
check the subframe bolts make sure they are tight, also did you check the swaybar endlinks? they couls aslo be a problem
