Vss Location - Page 7 - Taurus Car Club of America : Ford Taurus Forum
 4Likes
Closed Thread
post #62 of 68 (permalink) Old 07-01-2013, 04:42 PM
Originally Posted by travism View Post
Thank You! Thank You! Thank You!
This image really helped me find the VSS.
I am having a bear of a time, finding mine on my 95 Taurus, well documented and photodocumentd, to the ire of some, on Bob Is The Oil Guy. Some people rather really hate me and want to kill me over there.
Anyways, the part still needs to be changed, so, onward I go.
I appear to be looking in the wrong place. I am looking by the firewall. I will next focus on under Cylinder #2.. and I saw a video for an AX4N on Youtube out of a 96, mine is in a different place. His (96 3.0) is here
I will re-read the thread, I hope I didn't mash any gear so bad that fluid change and new sensors will smooth it out. My speedo dances, and my 1-2 shift is never the same twice. Can be everything from 100% perfect to "wow did the trans fall out after that."
Trying to apply this advice:
1- reach in with the left hand while standing at the right fender. Feel for the VSS just below the #2 cylinder. It is on TOP of the transmission. You may need to pull back a heat shield.
2- Pull off the electrical connector. Remove the 10mm bolt with a box / open end combo wrench.
3- The VSS pulls straight out toward the driver's side.
4- The new VSS pushes straight in toward the passenger side. Bolt it. Plug it. Drive it.
Any other "pro tips?" I have daylight, and a tool.
95GL is offline
post #63 of 68 (permalink) Old 07-01-2013, 04:48 PM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
Follow speedo cable to terminus on output shaft. They hang together
jag1959 is offline
post #64 of 68 (permalink) Old 07-01-2013, 05:02 PM
^^ Found it. The foil was in the way.
Now, to get it off.. Seems in a very tight/odd spot...
95GL is offline
post #65 of 68 (permalink) Old 07-01-2013, 05:09 PM
jag1959's Avatar
Work threads, be patient. Try going in through wheel well. Be sure to lube O-ring and insert end of sensor
jag1959 is offline
post #66 of 68 (permalink) Old 09-27-2013, 02:09 PM
No Overdrive
is the VSS located in the same spot on a 1997 Taurus 3.0 Lt.? I can't seem to figure out why I don't have overdrive..... The car runs great and shifts fine other than getting overdrive... If any answers,please feel free to let me know.....Thanks
birdman95 is offline
post #67 of 68 (permalink) Old 01-03-2016, 02:34 AM
Petr122 is offline
post #68 of 68 (permalink) Old 01-03-2016, 07:42 AM
jag1959's Avatar
The above video gives a clear indication of the location of the VSS on the AX4N.
BE WARNED IT LEAVES OUT STEPS AS FAR AS REMOVAL GOES AND PRYING ON IT IS NOT RECOMMENDED
SpartanFan likes this.
It's SHO time!
jag1959 is offline
Closed Thread
