1996-2007 Front Wheel Bearing Hub Replacement - Page 2 - Taurus Car Club of America : Ford Taurus Forum
 1Likes
post #11 of 15 (permalink) Old 07-17-2015, 09:54 PM
^ John, nice tutorial with pics! Would a 2-3 jaw gear puller help to push the axle shaft in more?
sheila is online now
post #12 of 15 (permalink) Old 07-18-2015, 09:33 AM Thread Starter
I'll Be Watching You!
sousa632's Avatar
Year: 2007
Model: OTHER
Engine: OTHER
You could use the puller just to keep it in place so it doesn't move, however I wouldn't suggest pushing the axle farther than the 'bind point' with it to prevent damage to the cv joint.
John
sousa632 is offline
post #13 of 15 (permalink) Old 12-09-2017, 12:07 AM
Hey Sousa. Just wanted to say thanks for writing this up. I wasn't really looking forward to this job but with your excellent write up I finished my passenger front in just a couple hours for my first time. You rock!
If anyone has trouble getting the hub out, I recommend checking out some youtube videos of people using bolts/nuts/couplers to press the hub off the spindle.
PS to hold the axle shaft in place I used the closed end of a wrench on one of the wheel studs, positioned the body of the wrench so it laid across the axle shaft, and tightened down a lug nut on the stud/wrench end.
2003 Taurus SES
e_93 is offline
post #14 of 15 (permalink) Old 12-09-2017, 09:42 AM
PS to hold the axle in place I used the closed end of a wrench on one of the wheel studs, positioned the body of the wrench so it laid across the axle shaft, and tightened down a lug nut on the stud/wrench end.
Can you post the link to the You Tube video you describe?
Automender12345 is online now
post #15 of 15 (permalink) Old 12-10-2017, 12:17 PM
I used this first method. I skipped the first step shown of using your power steering as a hydraulic press. 3/8" couplers and bolts will just fit in between the hub and the spindle for the Gen 4 Taurus. I got mine from Home Depot.
Another idea...
2003 Taurus SES
e_93 is offline
Torquing the front wheel bearing axle nut tread Maintenance and Repair 18 06-05-2015 03:01 PM
98 Wheel Bearing replacement? fordcdn Suspension, Handling and Brakes 27 05-04-2015 12:49 PM
Wheel bearing and wheel hub part question procter Maintenance and Repair 0 10-30-2014 11:57 AM
Front wheel hub replacement question Opfor2 Maintenance and Repair 11 07-20-2014 12:02 PM
Wheel bearing replacement on 1992 Sable compcat Maintenance and Repair 0 06-14-2013 05:46 PM
