Another Random misfire and surging thread - Page 4 - Taurus Car Club of America : Ford Taurus Forum
 1Likes
post #31 of 38 (permalink) Old 08-06-2019, 12:16 PM
You need to look at long term fuel trims on both banks at idle and engine under load like driving at 50 mph. High positive trims at idle that drop toward zero under load = vacuum leak.
These days a simple code reader doesnt cut it for diagnosing problems. You need a scan tool that will show what sensors are reporting to the PCM and what signals the PCM is outputting to various actuators.
Get Forscan (free download for PC) and a good quality ELM327.
post #32 of 38 (permalink) Old 08-06-2019, 02:52 PM Thread Starter
Model: Ford Taurus Wagon
Already downloaded and ordered as I had been thinking about this for a while. Thanks!
It'll be a couple of days before I get to play with it.
AnalogueGuy is offline
post #33 of 38 (permalink) Old 08-07-2019, 06:00 AM
Year: 2017
Engine: 3.5L Cyclone V6
Which ELM327 adapter is better, wired or wireless? Is one type better than another?
kekaye56 is offline
post #34 of 38 (permalink) Old 08-07-2019, 04:49 PM Thread Starter
I ordered a wired one. Cheaper.
post #35 of 38 (permalink) Old 08-08-2019, 02:31 PM Thread Starter
So, I got my new toy today and below is the log. I hope somebody can interpret it or at least tell me where else to look.
I can tell both o2 sensors are problematic, but one is brand new, the other is an old one. Neither presented any problem until I put the new ones in so I can't help but wonder if I have the wrong parts. I read elsewhere here about fuel pump module relays being a problem so I switched mine out--made no difference. Fuel pump driver module? Is that in the main computer?
I did replace it but maybe I should put the old one back in?
Thanks!
Log below:
===EATC DTC None===
Successful DTC reading, no error codes found
Module: Electronic Automatic Temperature Control
===END EATC DTC None===
===OBDII DTC P1132-C===
Code: P1132 - HO2S11 not switching correctly. Sensor indicates rich.
Status:
- Confirmed - malfunction is confirmed
Module: On Board Diagnostic II
Diagnostic Trouble Code details
Low Manifold Vacuum on TMAP systems only.
High Fuel Pressure
This DTC may be caused by :
Air intake restriction
===END OBDII DTC P1132-C===
===OBDII DTC P1152-C===
Code: P1152 - Lack of HO2S21 Switch Sensor indicates Rich
Status:
Suspect HO2S21.
Dirty air filter.
High fuel pressure.
Damaged fuel injector.
Suspect PCM.
===END OBDII DTC P1152-C===
===OBDII DTC P1233-P===
Code: P1233 - Fuel pump driver module offline
Status:
- Pending - malfunction is expected to be confirmed
Suspect FPM circuit.
Open or Shorted FPM.
Suspect PCM.
===END OBDII DTC P1233-P===
===ABS DTC None===
Module: Antilock braking system
===END ABS DTC None===
===PCM DTC P1233===
Module: Powertrain Control Module
Suspect PCM.
===END PCM DTC P1233===
===PCM DTC P1000===
Code: P1000 - On-Board Diagnostic (OBD) Systems Readiness Test Not Complete
Check of all systems is not complete since last memory clear.
--Possible Causes--
- The vehicle is new from the factory and has not yet been through a complete OBD Drive Cycle.
- The battery or PCM has been disconnected.
- An OBD monitor failure had occurred prior to completion of an OBD Drive Cycle.
- The PCM DTCs have been cleared as part of a service process.
Note: The only way P1000 can be cleared (removed) from memory is when all of the OBD monitors have been successfully completed during normal vehicle operation.
P1000 cannot be cleared from the PCM when: 1. The thermostat is stuck open and a DTC is not generated. 2. There is an open VSS circuit and a DTC is not generated. 3. If the vehicle has a Power Take Off (PTO), the circuit is shorted to VPWR or B+, or the PTO is ON during Self-test.
The purpose of the Diagnostic Trouble Code DTC P1000 is to indicate that not all of the On Board Diagnostics OBD monitors have yet been successfully completed. You may also refer to the OBD Drive Cycle defined under the Powertrain Control/Emission Diagnosis Manual-Diagnostic Methods or the Owner's Manual.
Remember: It is not necessary to remove P1000 from the Powertrain Control Module PCM by driving the vehicle.
===END PCM DTC P1000===
===PCM DTC P1132===
High Fuel Pressure
===END PCM DTC P1132===
===PCM DTC P1152===
Suspect HO2S21.
Dirty air filter.
High fuel pressure.
Suspect PCM.
===END PCM DTC P1152===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===GEM DTC B1352===
Code: B1352 - Ignition key in circuit fault
Module: Generic Electronic Module
===END GEM DTC B1352===
===ABS DTC None===
post #36 of 38 (permalink) Old 08-11-2019, 03:08 PM Thread Starter
So I now have BOTH new o2 Sensors in and I'm getting codes 1131,1132,1151,1152. I only changed these sensors on spec and had no codes before then. My Ford guy swears these are the right ones but I don't think so. I can't put the old ones back as I damaged one taking it out.
Can anyone give me guaranteed correct part numbers for the correct o2 sensors? I don't care what brand.
Thanks
post #37 of 38 (permalink) Old 08-11-2019, 07:57 PM
Like already stated you need to get a scan tool that reads live data and check your long term fuel trims. You may have a large vacuum leak.
Automender12345 is online now
post #38 of 38 (permalink) Old 08-12-2019, 01:21 PM Thread Starter
Well, I ran Forscan again and the log is attached below. To repeat: There were no indications of problems with o2 sensors until I put the new ones in. You will note one sensor indicates lean, the other rich. ??
I couldn't figure out in Forscan where LTFT was so I used my codereader, pics attached.
I've used my codereader several times over the past few weeks and this is the first time it's ever displayed any number in LTFT other than zero.
FWIW, these tests were run with the big line to the vacuum distribution thingy on the firewall pinched closed.
===EATC DTC None===
===OBDII DTC P1131-C===
Code: P1131 - Lack of HO2S11 Switch Sensor Indicates Lean
Status:
HO2S11 not switching correctly. Sensor indicates lean.
Air leaks at the exhaust manifold
Low fuel pressure.
Manifold vacuum leak.
HO2SHTR11 Heater Circuit Malfunction
===END OBDII DTC P1131-C===
===OBDII DTC P1132-P===
Status:
High Fuel Pressure
===END OBDII DTC P1132-P===
===OBDII DTC P1151-C===
Code: P1151 - Lack of HO2S21 Switch Sensor indicates Lean
Status:
Suspect HO2S21.
Ignition misfire.
Low fuel pressure.
Disconnected or Damaged vacuum hose.
Restricted or Damaged fuel injector.
Suspect PCM.
===END OBDII DTC P1151-C===
===OBDII DTC P1152-P===
Status:
Suspect HO2S21.
Dirty air filter.
High fuel pressure.
Suspect PCM.
===END OBDII DTC P1152-P===
===ABS DTC None===
===PCM DTC P1000===
--Possible Causes--
===PCM DTC P1131===
Low fuel pressure.
===END PCM DTC P1131===
===PCM DTC P1132===
High Fuel Pressure
===PCM DTC P1151===
Suspect HO2S21.
Ignition misfire.
Low fuel pressure.
Suspect PCM.
===END PCM DTC P1151===
===PCM DTC P1152===
Suspect HO2S21.
Dirty air filter.
High fuel pressure.
Suspect PCM.
===RCM DTC None===
===GEM DTC B1352===
===ABS DTC None===
ID:	209401   Click image for larger version
ID:	209403   Click image for larger version
