02 sensors - Taurus Car Club of America : Ford Taurus Forum
 1Likes
  • 1 Post By 46davis
post #1 of 2 (permalink) Old 05-20-2019, 09:56 AM Thread Starter
I’ve got a weird issue. I’ve searched and searched, so I’m making a post.
I had replaced my cats (the y cat assembly) about six months ago. Replaced injectors, got a vacuum hose too close to a hot area and it melted, causing a misfire code. Fixed that, code went away. Then started getting this lean code, random misfires and read could be a vacuum leak. Turns out I also forgot to plug a vacuum hose at the intake. Fixed that and the code went away. Then I got a code for bank 1 sensor 2 and bank 2 sensor 2 both for the heater part of the sensor. The after market y cat assembly didn’t account for a metal plate, which I didn’t notice when installing, and it bent and smooshed the wires on the bank2 sensor2. So, I had to cut the sensor to get it out and do a little fabrication to put a new one in. Now the codes are bank1 sensor 2 and bank2 sensor2 stuck lean. I’m lost. I did nothing to the other sensor but spray some electrical cleaner in the connections. Did that to all 4 02 sensors, just Incase there was grease in them. Had a little power steering leak that got them dirty. How did the code change? I feel like there’s another issue and the sensors weren’t really a problem. Any help appreciated.
2006 Ford Taurus, 130k miles.
CameronWilliams is offline
post #2 of 2 (permalink) Old 05-23-2019, 10:34 PM
Most likely an induction leak causing the PCM to try to compensate for it. Otherwise a bad injector is something I've seen.
Take off the plenum and examine it carefully, change the gaskets, clean up the mating surface on the intake manifold and put it back together. Could be a O2 sensor, but not often. I would bet not both of them at the same time.
kekaye56 likes this.
46davis is offline
2 dead o2 sensors? Sensors or wires? RayInStl Maintenance and Repair 15 12-18-2016 08:17 PM
2004 Rear Drum to Disk Conversion w/Active ABS Sensors leonedog Suspension, Handling and Brakes 7 07-02-2016 12:30 PM
TPMS info (tire warning light), sensors, and training behlinla 5th and 6th Gen Aesthetics, Interior, Wheels and Tires 2 11-16-2014 08:53 PM
Of major repairs, O2 sensors, and Check Engine lights jtrevor99 Maintenance and Repair 12 04-17-2014 06:08 PM
Changing O2 sensors cpusavant Maintenance and Repair 10 06-29-2013 10:44 AM
You may post new threads
You may post replies
