5.0 swap - Taurus Car Club of America : Ford Taurus Forum
post #1 of 6 (permalink) Old 03-16-2019, 08:07 AM Thread Starter
5.0 swap
On a scale 1-10. 5 being ive swapped a 400 smallinto a rx7 how bad will a full 97 taurus wagon full conversion to a mustang or crown vic rwd suspension 5.0 and everything else thatll go with it be
And any sugestions on the easiest mus/vic years to swap too
Stewart Cleveland is offline
post #2 of 6 (permalink) Old 03-16-2019, 09:31 AM
zenriddles's Avatar
I once had a 1991 Thunderbird 5.0 Sport. Body was rusting to hell and I loved that car.
I got the tape measure out on it and a 1997 SHO and the wheelbases and width were very close between the cars. I came pretty close to getting out the plasma torch, gantry, and welder.
If you are a good fabricator, I would consider this route - just splice them at the floor pan.
RICE - ITS WHATS FOR DINNER !
Eric Lehmann
Lots of V8 SHO's
zenriddles is offline
post #3 of 6 (permalink) Old 03-16-2019, 11:09 AM
TollKeeper's Avatar
Model: Mercury Montego
I think your biggest issue would be that the front of the Taurus has a engine cradle to mount the engine to, and the mustang uses the existing Uni-Body frame rails. Once you get a engine cradle fabbed to mount into the existing Taurus engine cradle mounts, the job would get a lot simpler. From there its just a matter of a tunnel for drive shaft, and figureing out if you could fab in a independent rear drive axle, or go with a live beam axle. I have seen someone turn a Pontiac Grand Prix from a FWD setup to a RWD setup with a LS engine, and a Live Beam axle. So I am sure it can be done.
Brian - Carpe Diem
2005 Mercury Montego 52k
2004 GMC Envoy XUV 182k
TollKeeper is offline
post #4 of 6 (permalink) Old 03-18-2019, 07:50 PM
Maybe 10 as it is a complete engine and drivetrain swap.
It has been done once with the SHO engine and apparently someone did it with a 5.0 already.
92 White SHO
loudsho92 is offline
post #5 of 6 (permalink) Old 03-18-2019, 08:26 PM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
Enough time, effort and money and you can do almost anything
It's SHO time!
jag1959 is offline
post #6 of 6 (permalink) Old 03-19-2019, 07:36 PM
I'll Be Watching You!
sousa632's Avatar
Year: 2007
Model: OTHER
Engine: OTHER
Money being the biggest item being spent
John
sousa632 is offline
Crazy Swap: Part 2 Piggybear Engine and Drivetrain 16 11-27-2016 05:16 PM
radio swap digital to analog heat control kingsblend420 Electronics, Security, Audio and Visual 3 10-18-2016 02:15 PM
2001 w/ Vulcan 3.0 engine swap info SES Steve Engine and Drivetrain 72 09-20-2016 02:40 AM
Can you swap a non flex fuel motor into a flex fuel car? taurusflip Maintenance and Repair 5 01-20-2014 10:30 PM
Dash swap.... warrenj42 Aesthetics, Interior, Wheels and Tires 3 01-13-2014 07:50 PM
