only runs in acceleration mode - Page 2 - Taurus Car Club of America : Ford Taurus Forum
 1Likes
post #11 of 11 (permalink) Old 05-01-2019, 03:21 PM Thread Starter
Update:
Although the problem was the MAP sensor, I found that out by accident. The schematic in Chilton's uses a variable resistor symbol for the MAP. It is not! The MAP is a variable pulse width generator. You need your scope to measure the output. I got lucky when I decided it was faulty due to lack of output voltage variation.
I bought a new MAP from Hong Kong (sinyoauto2011) and it was a POS. The thing fired right up, but driveability was crap. It had a 2 second recovery time after any decrease in pressure. i.e. Whenever I lifted my foot, partially or completely, it would bog when I put my foot back in it. When starting from stop it would launch really hard after the delay, spinning wheels etc. Gas mileage was cut in half to 10mpg. This new MAP has no numbers on it so I wonder if it failed final inspection and was rescued from the trash.
I found an old Lariat F150 in a boneyard with the hood off and no engine. The electrical plug was still connected to the MAP, but not the vacuum so rainwater could have entered it, but for $5 it was worth trying. I swapped it out in the parking lot and it has been running beautifully ever since with driveability and gas mileage restored.
I'm trying to get a refund, but even if I do, with gas at 3 dollars per gallon I have paid dearly for this "new" part.
ddan is offline
2008 Taurus X Limited hvac stuck in vent mode...... jonderson25 5th and 6th Gen Maintenance and Repair 4 02-06-2019 08:36 AM
Mode Door Actuator (2008) 10139 5th and 6th Gen Maintenance and Repair 11 04-24-2015 10:32 AM
Experimenting With Engineering Test Mode behlinla Maintenance and Repair 26 09-11-2014 09:46 PM
Sable '04 DOHC unable to accelerate, runs rough, stumbles mysable2002 Maintenance and Repair 15 07-15-2014 12:56 AM
Misfire Diagnosis Using Mode $06 (Advanced) Sam Maintenance and Repair 14 06-02-2014 12:24 PM
You may post new threads
You may post replies
