98 Taurus 24V DOHC Transmission issues - Taurus Car Club of America : Ford Taurus Forum
post #1 of 5 (permalink) Old 08-14-2017, 03:27 PM Thread Starter
CKA
Year: 98
I am hoping I am headed in the right direction....
Transmission lines went out, had to have vehicle towed (battery disconnected)
Lines replaced...drove great for approximately 10 days. Fluid levels good.
Drove approx. 10 miles, tranny went into neutral, then re-engaged. Stopped to get gas. Car started great, with no issues to home.
Next day, warmed car, fluid levels down. Filled, drove later in day, drove great, no slippage, through the gears with no hesitation. Waited til next morning to check again. Put vehicle into reverse, then into Drive...seemed like it went into neutral. Shut vehicle off, waited 5 minutes, restarted...reversed, then into Drive. No problems, no issues.
To me this does not directly sound like a transmission issue...more of electronic issue. Such as when the computer re-booted it did not re-boot properly....VSS sensor, or ??? Any help would be greatly appreciated.
CKA is offline
post #2 of 5 (permalink) Old 08-14-2017, 06:17 PM
Year: 1999
Model: Ford Taurus Wagon
When VSS starts to fail the tach works just fine but speedometer will not move if analog (not sure about digital) and transmission will stay in first gear then rev high rpm, then violently shift hard into second. What is the mileage on the transmission? Takes a while for VSS to throw error codes if they ever do.
james27613 is offline
post #3 of 5 (permalink) Old 08-14-2017, 07:28 PM Thread Starter
CKA
Year: 98
Vehicle has 149,000
CKA is offline
post #4 of 5 (permalink) Old 08-14-2017, 07:29 PM Thread Starter
CKA
Year: 98
Vehicle has 149,000. To my knowledge 1st time issues have come up
CKA is offline
post #5 of 5 (permalink) Old 08-14-2017, 08:35 PM
Did you figure out why the fluid level dropped?
Overheating issues (2001 FORD Taurus DOHC) carrzkiss Maintenance and Repair 24 10-27-2016 01:03 AM
2010-2014 Taurus Known Issues? ricer333 5th and 6th Gen Maintenance and Repair 20 04-29-2015 04:15 PM
2000 Ford Taurus DOHC Wagon, no problem, for $1.2k daydaydvd Cars For Sale 9 06-13-2014 04:53 PM
'97 LX issues - Can transmission just go out? Slicer89 Engine and Drivetrain 6 12-05-2013 09:55 AM
96 taurus ax4s only moves after transmission warms up asmsalem Maintenance and Repair 14 07-16-2013 01:03 AM
You may post new threads
You may post replies
