Pcv valve location - Page 2 - Taurus Car Club of America : Ford Taurus Forum
 2Likes
post #11 of 18 (permalink) Old 08-20-2017, 09:41 AM Thread Starter
Originally Posted by chartmaker View Post
Pic of one I made. I whittled out the wood peg, heated the PCV pipe coupling with a heat gun and pushed the wood pig into it, used a vice to square up the PVC to the peg. Masking green tape there to grip the valve for installation, to hold the valve straight. I used the 7/8" 12 point socket for my first one. Need a real good socket that is open inside for clearing the nipple. I had to insert my extension part way to make it work. Used the plastic tool since, and had to do my '03 sedan twice. Bought a store brand PCV and it made it idle very fast. MC from RA and it is like new. Way too much work for having to do over with junk parts house part.
Ok so I'm confused as to how it goes in. Which way does it go in? Because right now the one that is in my engine has it facing with the nipple going in. Is it supposed to be opposite? Or which side goes in and which side stays out
Sent from my Z981 using Tapatalk
spellman1989 is offline
post #12 of 18 (permalink) Old 08-20-2017, 10:38 AM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
It can only go in one way. If you look at your bottom pick you can see the slots for the twist lock that holds it in place and the o-ring that would serve no purpose on the hose end.
jag1959 is offline
post #13 of 18 (permalink) Old 08-20-2017, 03:12 PM
^^ Yep. ^^
Having the old one in backwards would cause all kinds of problems, I suppose.
2003 Mazda Protege5, 2.0L (Daughter #1)
2008 Nissan Titan SE, Crew Cab/Long Bed, 5.6L (Mine)
2007 Volvo V70 2.5T, turbo 2.5L (Mine)
2010 Mazda 6 Grand Touring, 2.5L (Daughter #2)
2012 Toyota Camry LE, 2.5L (Wife)
Exocet is online now
post #14 of 18 (permalink) Old 08-20-2017, 03:14 PM Thread Starter
Ok so the old one is definitely in backwards
post #15 of 18 (permalink) Old 08-20-2017, 03:21 PM
jag1959's Avatar
Can't see how that would be possible given the different diameters. Would definitely like to see pics and a vid of it in place and during removal.
jag1959 is offline
post #16 of 18 (permalink) Old 08-20-2017, 03:33 PM Thread Starter
Do you know how to move the wiring harness out of the way so I can access it easier?
post #17 of 18 (permalink) Old 08-26-2017, 07:12 AM Thread Starter
So I finally got everything hooked up properly the pcv valve was indeed in backwards. I don't get how it ran good all those years without messing up. Can bad gas mess up a pcv valve?
post #18 of 18 (permalink) Old 08-26-2017, 11:23 AM
jag1959's Avatar
Where are the pics?
jag1959 is offline
2005 taurus pcv valve location txparkway Introduction Forum 5 10-21-2014 11:00 AM
2000 Vulcan Location Fuel schrader valve and Fuel pressure Regulator? q0987 Maintenance and Repair 27 02-06-2014 12:07 PM
PCV valve location? orange_kittys Maintenance and Repair 5 06-20-2013 12:14 PM
IAC valve location? zinger Maintenance and Repair 2 05-08-2013 04:53 PM
You may post new threads
You may post replies
