Taurus does not go more than 15 miles per hour - Taurus Car Club of America : Ford Taurus Forum
 2Likes
post #1 of 33 (permalink) Old 08-02-2017, 10:13 PM Thread Starter
Year: 1992
Hi,
I have 1992 Taurus 3.0L Engine. Taurus does not go more than 15 miles per hour on plane road. Up the hill between 15 and 25
miles per hour. Down the hill, Taurus can go 45 mph easily.
What could be the problem. Please help me.
Thanks a lot for help.
Doug
Doug is offline
post #2 of 33 (permalink) Old 08-03-2017, 10:10 AM
Plugged cat(s)??? Tranny problems?
sheila is online now
post #3 of 33 (permalink) Old 08-03-2017, 04:06 PM Thread Starter
Year: 1992
Thank You.
Its a Transmission Problem? or Cat problem?
How can I isolate the exact problem?
Thanks.
Doug
Doug is offline
post #4 of 33 (permalink) Old 08-03-2017, 04:25 PM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
Any codes? Misfires or stumbling? Is the engine revving? Trans slipping? Is it better when cold? A little more info would be helpful.
RLW001xxx likes this.
jag1959 is offline
post #5 of 33 (permalink) Old 08-03-2017, 09:48 PM Thread Starter
Year: 1992
Thanks.
Engine runs good. Exhaust gas coming out of muffler. On down the hill is no problem. Up the hill and plane road is the problem.
Doug is offline
post #6 of 33 (permalink) Old 08-11-2017, 10:57 AM Thread Starter
Year: 1992
Today car passed the inspection. but problem is still there of speed. How do I know its a transmission problem or Catalytic converter plug problem?
Thanks.
Doug
Doug is offline
post #7 of 33 (permalink) Old 11-04-2017, 10:08 AM Thread Starter
Year: 1992
Code is 1-1-1
Down the hill it can go 50 miles per hour easily. Up the hill can not go 25 miles per hour.
Thanks.
Doug
Doug is offline
post #8 of 33 (permalink) Old 11-04-2017, 12:55 PM
redhousenine's Avatar
Verify that the transmission is shifting correctly. You should feel it shift gears as you take off from a stop. Also, watch the tachometer as the needle should drop down when it shifts into a higher gear. If you don't have a tachometer, listen to the sound of the engine as it should change in tone when shifting. If neither happens, then it sounds like your transmission is stuck in 1st gear.
If the car passed inspection, then I doubt that the catalytic converters are bad, or that there's a problem with the engine.
2005 Taurus SE
Vulcan OHV Engine
redhousenine is offline
post #9 of 33 (permalink) Old 11-04-2017, 04:36 PM Thread Starter
Year: 1992
It shifts smoothly from stop. I have no tachometer. When speed reached 25, and I press gas for more speed engine changes tone in loud sound. Again, when speed dropped down to less than 15, I press gas and speed reached to 25, for more speed I press gas, than engine makes tone in loud sound. Down the hill, no pressing on gas, and speed reached to 50 with smooth shift in gears.
For inspection, they told me for old car just visual inspection. no hooking up.
Thanks.
Doug
Doug is offline
post #10 of 33 (permalink) Old 11-04-2017, 07:50 PM
Thanks.
Doug
Definitely sounds like the transmission is stuck in 1st gear. The PCM is likely limiting the RPM's for that gear, which is making it difficult to reach 25 MPH. Though I can't figure out how coasting down a hill would allow it to shift again. Could be something a simple as a senor.
Also, while coasting down a hill, does it feel like the car gradually slows down? (Engine braking)
2005 Taurus SE
Vulcan OHV Engine
2013 Ford Taurus Limited Water Pump gone bad at 72,457 miles Tulips001 Introduction Forum 5 02-19-2016 10:53 AM
'03 Taurus owner, 235K miles and counting scannit Introduction Forum 5 11-02-2014 08:37 PM
How To Get 200k Miles From Your Taurus!!!!! GOBULLGO Maintenance and Repair 53 11-06-2013 09:08 PM
'97 Taurus 3.0L 205k miles: Just Poured Prestone PS Fluid into PS Reservoir Colt Hero Maintenance and Repair 5 09-23-2013 12:21 PM
2007 Taurus SE, Belt Tensioner, 79k miles patrickray Maintenance and Repair 6 07-28-2013 09:51 PM
