Duratec Power Loss - Page 2 - Taurus Car Club of America : Ford Taurus Forum
 11Likes
post #11 of 20 (permalink) Old 07-18-2017, 09:19 PM Thread Starter
Thanks John. I'll give it a few taps tomorrow night.
sousa632 likes this.
Exocet is offline
post #12 of 20 (permalink) Old 07-19-2017, 08:03 PM Thread Starter
Well, I tapped around the exhaust a bit tonight. Right on the rear cat, it's hard to tell. Too many other rattles in the exhaust. On the pipe in front of the rear cat after the "Y", it does sound like there's something loose in there. On the front pipe, ahead of the "Y", it sounds clean.
So, my best guess is the cat on the backside of the engine failed and spewed it's remains into the exhaust clogging up the rear cat.
2003 Mazda Protege5, 2.0L (Daughter #1)
2008 Nissan Titan SE, Crew Cab/Long Bed, 5.6L (Mine)
2007 Volvo V70 2.5T, turbo 2.5L (Mine)
2010 Mazda 6 Grand Touring, 2.5L (Daughter #2)
2012 Toyota Camry LE, 2.5L (Wife)
Exocet is offline
post #13 of 20 (permalink) Old 07-19-2017, 09:58 PM
I'll Be Watching You!
sousa632's Avatar
Year: 2007
Model: OTHER
Engine: OTHER
Not a really great video but it's 6 years old.
I now know that when I tapped on the rear bank cat there was nothing in it and all that rattling is the substrate pushed to the rear cat. Does it sound like that?
John
sousa632 is offline
post #14 of 20 (permalink) Old 07-20-2017, 12:07 PM Thread Starter
It doesn't sound that loose when I tap the cat. But, the pipe in front of the cat sounds more like that. Maybe not quite as much stuff. I'm dropping it off at the shop tomorrow to have them take a look.
Exocet is offline
post #15 of 20 (permalink) Old 07-21-2017, 03:09 PM Thread Starter
Got some good news and bad news from the shop. The good news is it's the rear cat that's plugged. The bad news is my car is a C.A.R.B. compliant car.
The cheap-azz side of me says to pull it off and punch it out. No emissions testing in my area, other than a CEL test. So, no issues there. But, the pipes into or out of the cat aren't straight. Might be more work than I want to do.
I did find a C.A.R.B cat on RA for $216. Better than the $600+ the local parts stores want.
Exocet is offline
post #16 of 20 (permalink) Old 07-21-2017, 05:19 PM
The question is what plugged it? If it is melted then ok it's from misfire but if not then it maybe the upstream cat breaking up. A non CARB cat is better that no cat.
post #17 of 20 (permalink) Old 07-21-2017, 05:47 PM Thread Starter
The upstream cats were fine.
Exocet is offline
post #18 of 20 (permalink) Old 07-23-2017, 11:08 AM
Owner of #RaceSable
ShelbyRacer78's Avatar
Year: 2002
cut the cat off, you don't need to pass any kind of emissions testing. no CEL will come on and the car will be fine. Oh and the throttle response will be better.
Mark
2002 Sable LS Premium (Allison) COTM Winner 6/14
2006 Taurus SE (My grandmother's)(I'm the caretaker for it)
2001 Sable LS (Ashley) (Gone but not forgotten)
Real Car Guys Like Every Car
Northeast Chapter Mod
Northeast Members Please Post Your Info and Your Location. Links Below:
ShelbyRacer78 is offline
post #19 of 20 (permalink) Old 08-01-2017, 08:20 PM Thread Starter
Got the car back today after the second go-round on replacing the fuel injector seals. Don't appear to have any leaks. The leak was in the #1 and #4 injectors. After fixing those, the #6 started leaking. The mechanic was having a tough time getting everything lined up and put into place without damaging a seal. But, the 3rd time appears to have been the charm.
The car seems a lot peppier, from even before the cat melt down. Top end is a lot stronger. Makes me think the cat was slowly failing over time. They gave me my old cat back to recycle, might get $20 for it.
ShelbyRacer78 likes this.
Exocet is offline
post #20 of 20 (permalink) Old 08-05-2017, 09:08 PM Thread Starter
As an indication of how bad it was, my mileage for the past 2 weeks was 17.8 MPG. That was about 2/3 of the miles with it blocked, 1/3 of the miles after being fixed. Normally, I'm 20-22, without any extended highway driving.
I have also noticed that the exhaust is louder now. The old cat must of muffled things down a bit.
Exocet is offline
Loss of power when accelerating. Mathias1701 Maintenance and Repair 12 04-14-2017 01:12 PM
Seeming misfires, excessive power drain when AC is on (3.0L Duratec) The White Falcon Solutions to Common Problems and 'How To' Articles 6 06-18-2014 02:44 PM
Hypertech Vs. SCT: A Review Sam Taurus and Sable General Discussion 2 09-08-2013 11:01 PM
