[Urgent] Transmission shifting hard after transmission fluid change at dealership - Page 3 - Taurus Car Club of America : Ford Taurus Forum
 15Likes
post #21 of 21 (permalink) Old 09-03-2017, 01:53 AM
Year: 2004
I've had Motorcraft Mercon V, Pennzoil Multi Vehicle and Valvoline "for Mercon V applications" in my AX4N.
The Valvoline used to be an approved Mercon V.
Motorcraft Mercon V - felt fine
Pennzoil Multi Vehicle - I didn't like it
Valvoline "for Mercon V applications" - feels better than Motorcraft (it better had since I still have 50+ quarts of it)
It's mostly about having the correct friction modifier in the fluid. Viscosity doesn't matter so much anymore since modern lower viscosity fluids are shear stable so are actually as thick or even thicker as older ones which only start thick but then end up thin.
Many feel that multi vehicle friction modifiers can't satisfy multiple specifications. Only a few people in the industry are qualified to comment on whether that is true. However, my butt dino told me that Pennzoil Multi Vehicle wasn't similar enough.
Lastly, I've seen many many stories of complaints about ATF and while sometimes it's an incompatible fluid, it's never about a different brand of an approved fluid and mostly it's about being under or over filled.
2004 Taurus SES Duratec 110k
rjacket is offline
Ford Taurus 2004 SES, 24V, DOHC Transmission Fluid Change Mansour Taurus and Sable General Discussion 1 05-23-2017 06:19 AM
Leaking Transmission Fluid plewispm Engine and Drivetrain 5 04-08-2017 06:45 PM
Gen 4 Trans Pan Drop and Filter Change AX4N Sam Solutions to Common Problems and 'How To' Articles 145 08-21-2016 01:31 PM
When (or Even If) To Replace Transmission Fluid And Filter? Brcobrem Maintenance and Repair 36 02-08-2015 10:47 AM
Transmission Fluid Advice Aufdej Engine and Drivetrain 10 08-24-2014 01:59 AM
You may post new threads
You may post replies
