02 duratec 3.0 24v dohc vin s low idle misfire - Taurus Car Club of America : Ford Taurus Forum
post #1 of 11 (permalink) Old 03-04-2017, 05:10 PM Thread Starter
Year: 2002
Unhappy 02 duratec 3.0 24v dohc vin s low idle misfire
ok so i bought the car from an auction check engine light was not on (i assume since the car had to be jumped to get through the line) she is an 02 sable ls premium with 65k miles. check engine light started flashing i assumed the normal misfire and had her plugs wires and even the cylinder #4 fuel injector changed. still she was throwing p0304 and p0305 at me.
didnt even get to leave the mechanic and the CEL was on steady now and also flashing for the random misfire. i left her there. he did a compression test and it showed that cylinder number 4 was at about 100. so clearly there is a compression issue and there is a leak somewhere.my mechanic assumed my exhaust valves were dirty and just not seating correctly at low idle due to the condition of the motor and amount of miles he and i hope and highly doubt the valve is bent/burnt or has a broken ring. he removed the exhaust manifold (headers as some would say) and sprayed the valves with some seafoam and tried to clean em up. he said they were pretty caked up. (at least this is what he told me)
i tried running some seafoam through the throttle body (although half of it didnt make it in because i messed up) and that didnt work so i shall try this again
i put some marvel mystery oil in the motor and in the gas tank (i have only used about a 1/4 tank so far) light is still on
i even tried an old school mechanic trick someone told me and put some water in the throttle body in hopes of the steam cleaning the motor. light is still on.
im no mechanic but i would like to believe it is due to buildup on the valves seeing as the car runs flawless on the highway.
however when i get off the highway and sit at a red light she misfires and starts flashing. does not flash while on the highway only at low idle.
p0304 and p0305 are the only codes coming up period. there are no other codes stored or pending. i was told by another mechanic there are no vacume leaks as the car would be throwing lean codes at me
if i had a bent/burnt valve or bad ring wouldnt the car still misfire at higher speeds while on the highway?
please someone help before i throw any more money into this car.
ezonerrdub is offline
post #2 of 11 (permalink) Old 03-04-2017, 06:31 PM
Coil pack.
Jeff K is online now
post #3 of 11 (permalink) Old 03-04-2017, 06:40 PM Thread Starter
Year: 2002
@Jeff K do you think the coil pack would cause compression issues?
post #4 of 11 (permalink) Old 03-05-2017, 10:51 AM Thread Starter
Year: 2002
LOOK AT THIS COIL PLEASE
so i posted another thread explaining my problem which you can read here
https://www.taurusclub.com/forum/87-e...e-misfire.html
i pulled the coil to look at it myself after many people said its the coil pack and i even suspected it was the coil pack
my question now is.
is this coil bad? i dont see any cracks except one mark that looks more like a scratch. its very very faint and i tried my best in the pictures so you can see it.
also
i hear these motors are very specific when it comes to parts. i dont believe this is a motorcraft coil could that be my issue if it is the coil pack? could it be that scratch/crack?
( second to last picture is where you can attempt to see the very faint scratch/crack)
ID:	188474   Click image for larger version
ID:	188482   Click image for larger version
ID:	188490   Click image for larger version
post #5 of 11 (permalink) Old 03-05-2017, 12:34 PM
Pic of Motorcraft coil cracks. If it is not MC, does not matter if it is cracked or not. Risky.
Plugs and plug wires must be top notch for "waste spark" systems as in coilpack.
chartmaker is online now
post #6 of 11 (permalink) Old 03-05-2017, 01:44 PM Thread Starter
Year: 2002
thanks for the pic. i have compared and come to the conclusion mine is not a motorcraft coil. i will be changing and updating very soon.
post #7 of 11 (permalink) Old 03-05-2017, 02:31 PM
The White Falcon's Avatar
Year: 2010
Engine: 3.5L Cyclone V6
You can get a BWD coil as well; they're the OEM for Motorcraft on that part and by all accounts they still maintain the same quality.
The White Falcon is offline
post #8 of 11 (permalink) Old 03-05-2017, 02:37 PM
That coil pack is junk. A noted above, replace with Motorcraft or BWD.
post #9 of 11 (permalink) Old 03-09-2017, 07:40 PM Thread Starter
Year: 2002
@Jeff K @chartmaker @The White Falcon
so i have changed the coil with a oem motorcraft coil and she is still misfiring...
post #10 of 11 (permalink) Old 03-09-2017, 07:48 PM
repairman54's Avatar
You still have plugs and wires that can give you issues. Since you don't know the cars history who know how old those parts are.
John
'11 Tahoe
'09 Malilbu LS
'03 Sable LS 24v
'05 Sable 24v son's
'01 FLHR
Ski Doo's Sea Doo
Previously enjoyed vehicles
'07 Mustang GT 3 pedals
'89 S10 Blazer 4x4
'75 Cordoba
'68 GTO
'68 Chrysler Newport 2dr
'67 Chevy Caprice 2dr
'67 Chevelle
'65 Bonneville
'65 Chevelle
'64 Olds Jetstar 88
repairman54 is offline
24v Duratec DOHC Misfire sshawn Maintenance and Repair 30 07-08-2015 10:28 AM
Misfire Diagnosis Using Mode $06 (Advanced) Sam Maintenance and Repair 14 06-02-2014 12:24 PM
2004 Sable 3.0 DOHC - Misfire - Bad ignition Coil Codes - PCM issues: PLEASE HELP! 2004Sable Maintenance and Repair 5 05-03-2013 01:37 PM
