how to prevent cracked heads - Taurus Car Club of America : Ford Taurus Forum
post #1 of 8 (permalink) Old 09-06-2016, 03:25 AM Thread Starter
Year: 1997
Model: Ford Taurus Wagon
so i have the 3.0l vulcan and i heard the head may crack on this engine. i want to know how to prevent this other not overheating the engine
David Chemi is offline
post #2 of 8 (permalink) Old 09-06-2016, 07:44 AM
Top 3: cooling system maint, repeat, repeat.
If you have not replaced the OEM rad cap with the revised MC cap, do so at once. RS-527.
chartmaker is online now
post #3 of 8 (permalink) Old 09-06-2016, 08:42 AM
^^^^^ +1000
If you keep the cooling system maintained the engine will never overheat and never crack or warp the heads.
Vulcan heads are no more prone to cracking / warping than any other engine.
Jeff K is online now
post #4 of 8 (permalink) Old 09-06-2016, 09:15 AM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
^^+1
With Chart and Jeff, keep the cooling system maintained. Never once heard of a head fail in a Vulcan that did not involve an overheat.
jag1959 is offline
post #5 of 8 (permalink) Old 09-06-2016, 11:30 PM Thread Starter
Year: 1997
okay got it and change the cooling cap too okay
post #6 of 8 (permalink) Old 09-15-2016, 09:49 AM
If your ever at the upull yard, you can tell a overheated Vulcan by all the brown sludge
in the degass tank. If you see that you know the coolant is compromised and it has
either overheated or it will.
bob
soundu is offline
post #7 of 8 (permalink) Old 09-15-2016, 10:17 AM
There also is a possibility of head damage from pre ignition or knock. Some Taurus are prone to it due to errors in the octane settings in the PCM. I believe one of my 2001s with 166k miles may have a small crack in the spark plug area. It maybe leading to a sporadic and infrequent misfire on #3 cylinder. It always had a spark knock for years.
post #8 of 8 (permalink) Old 09-17-2016, 03:54 PM Thread Starter
Year: 1997
I see cause sometimes by my heads they're a little wet on sides by the freeze plugs
Blown Head Gasket - Should I replace the Cylinder Heads? mdtobe Maintenance and Repair 11 08-18-2016 01:03 PM
Bolt on heads christopehr7613 Maintenance and Repair 11 01-25-2015 12:03 PM
Possible cracked engine block msclark3 Maintenance and Repair 5 05-17-2014 09:24 AM
cracked heads, next best choice? jbh425 Maintenance and Repair 4 04-07-2013 04:55 PM
