Duratec from gen 3 or 4 in aerostar - Page 2 - Taurus Car Club of America : Ford Taurus Forum
post #11 of 15 (permalink) Old 04-27-2014, 11:02 PM
it'sthatcar's Avatar
Chapter: Northern
Originally Posted by The White Falcon View Post
Escape is FWD I thought. AWD is a whole different ball game.
Escapes came in AWD, or RWD with optional 4WD, as I understood it. I could be wrong though.
Edit: Just kidding. I checked and apparently all Escapes are FWD or AWD, no RWD applications. You learn something new every day.
David
it'sthatcar is offline
post #12 of 15 (permalink) Old 04-28-2014, 06:52 AM
Spend my 02 wisely...
madscientist's Avatar
Actually wiring an EEC-V into an older vehicle isn't super difficult, though it certainly isn't plug and play. As mentioned, the transmission is indeed the issue here. Ford has never made a RWD transmission with the Duratec bolt pattern. Even the 4WD/AWD Escapes use a FWD engine/transmission setup. Even if you were to modify the bellhousing on an existing transmission or have an adapter plate made, getting the Duratec's EEC-V PCM to control that transmission is not likely to happen even with custom tuning. You'd pretty much be required to adapt an MTX, and I can't think of one off the top of my head that would be suitable to even attempt adapting. The Duratec has a very unique bolt pattern.
Basically what I'm saying is that with enough time and money it figuratively could be done, but there'd be a lot of wiring and custom machine work to be done. Custom bellhousing, motor mounts, etc. Just a train of thought though, the SHO V6 has the same bolt pattern as the Vulcan.....
-Jonathan
madscientist is offline
post #13 of 15 (permalink) Old 04-28-2014, 08:23 AM
The White Falcon's Avatar
Year: 2010
Engine: 3.5L Cyclone V6
Not to mention it's EEC-IV, correct?
The White Falcon is offline
post #14 of 15 (permalink) Old 04-28-2014, 08:41 AM
Yep, and the RWD Vulcan motor mounts will bolt right up to it. You can also reverse the intake manifold so the throttle body is at the front of the engine. I've seen them swapped into Rangers several times. It really is all but a bolt in swap for the Vulcan. The question is if the wider SHO intake manifold and heads will fit in the tight confines of the Aerostar engine bay. It's not really any bigger than the Duratec though, so if it won't fit the Duratec likely wouldn't either.
-Jonathan
post #15 of 15 (permalink) Old 04-28-2014, 01:34 PM
Cool
Go for the SHO V6!
92 White SHO
loudsho92 is offline
Need a new Bull. Duratec or Vulcan? Rochev Maintenance and Repair 12 01-12-2014 01:01 PM
2002 Duratec Swap Into 2000 Duratec Any Issues? gghs1981 Engine and Drivetrain 1 11-14-2013 07:45 AM
3.2L SHO V6 vs. Duratec 30 V6 URTOAST Engine and Drivetrain 39 08-19-2013 12:37 PM
Duratec Connecting rods fordlover35 Engine and Drivetrain 8 05-28-2013 06:14 PM
