Time For New Fuel Injectors? - Page 2 - Taurus Car Club of America : Ford Taurus Forum
post #11 of 13 (permalink) Old 05-09-2014, 07:57 AM Thread Starter
A new Motorcraft coil pack is on the way. Being an electrical engineer, the resistance of the sparkplug wires was the first thing I tested. I even substituted a wire from another set for the affected cylinder.
Tom Evans
1992 Gen 2 Vulcan (sold at 232,000)
2002 Gen 4 Vulcan 209,000
2002 Chev Suburban 157,000
1981 Mercedes 300SD 289,000
1982 Mercedes 300SD 307,000
Tom9489 is offline
post #12 of 13 (permalink) Old 05-09-2014, 09:39 AM
Maybe you have a comment about carbon tracking.
I had this twice on the same car, year apart. Paid Ford garage to diag, they said wires #2 #3 carbon tracked. I let them put new wires on. Then I got it home, running fine, so I changed all the plugs. Same thing one year later, #1 as in the pic. I replaced only one wire with a used one and used good plug.
There is a difference between the upper damaged plug and the lower good plug. It is the top connection, Upper plug is loose in any wire. Bottom one is tight in any wire.
This does not misfire. Makes the car run bad. Recording says this causes the spark timeing to way out of line random spark advance jumps according to the OBDII.
So, we have a spark running around inside the boot, but not going to ground.
What the hey!
chartmaker is online now
post #13 of 13 (permalink) Old 05-14-2014, 03:44 PM Thread Starter
I put in the new Motorcraft coil pack today and the problem was solved!
Tom Evans
Tom9489 is offline
Engine power goes down time to time - fuel pressure issue mbarazeen Maintenance and Repair 33 12-10-2013 10:39 PM
1996 Taurus/Sable Fuel Pump Problems - pressure does not build up quickly or hold. MalibuMarkham Maintenance and Repair 7 08-28-2013 07:51 AM
