Engine Specs - Page 2 - Taurus Car Club of America : Ford Taurus Forum
post #11 of 15 (permalink) Old 04-15-2014, 10:11 AM
Spend my 02˘ wisely...
madscientist's Avatar
I'm attaching the factory assembly manual just so you have it. It's not particularly specific, but it may be helpful. I'm also attaching the manual for the piston/rod assembly.
Originally Posted by powertripp View Post
I will admit though. I'm a newb at this engine stuff but I understand the rebuild stuff for the most part. I would love to purchase some new piston heads for this engine, some decent ones atleast. I have no idea what to get though.. any comments/suggestions??
I'm not sure what you're talking about when you say piston heads. Are your referring to the pistons or the cylinder heads? Either way, there's not really anything out there that would be an "upgrade". As for the pistons, if the cylinders are out of spec, the cylinders should be bored and new over-sized pistons should be installed. Even if the cylinders are in spec, they should be honed. The new rings won't seat properly if they aren't. As for the heads, the valves, valve seats and valve guides should be thoroughly measured and inspected. The mating surface should also be checked for flatness and the entire head should be checked for cracks. If anything is out of spec they should be rebuilt or replaced with remanufactured heads.
Also, just want to be sure. Is this ring pattern universal? Top ring = compression middle = compression. bottom = oil set up ring? Or can this pattern be switched at all?? I'm not going to do it, just really don't want to mix it up on accident.
The grove in the piston for the oil control rings is much wider than the grooves for the compression rings. The rings are also easy to differentiate. The oil control rings are thinner than the compression rings. The spacer that goes between the oil control rings is obviously pretty easy to differentiate.
As for your previous questions about the rod bolt torque specs, the factory manual only states that they should be torqued to 26 ft.lb. in pairs. In my experience, the best course of action is to get there in two or three steps. For example, I'd starting by torquing both bolts to 15 ft.lb. Then torque them to 20 ft.lb. and finally torque them to 26 ft.lb.
-Jonathan
madscientist is offline
post #12 of 15 (permalink) Old 04-15-2014, 02:20 PM Thread Starter
I know don't know where your getting all of this but it's completely awesome! lol
But yea, sorry about that, should of specified better. At least in that, I know that I got this all perfectly straight to do this job. Every thing you've told me about, I've re-read over and over. Thats a good sign! Thanks so much for all the info man, I truly appreciate it!!
I was asking about the piston head (ontop of connecting rod) though, not the actual engine head. I really want to order some hyper-eutectics.. It sucks though because I don't know if I'll need to bore the holes until I get this apart.. They'll probably just need a good honeing/deglazing which I will do. Just wonder if I should order the standard size pistons for my engine or not.. idk.. or even if I could just reuse the pistons already in the engine?? Could I get away with that? (obviously if their not too worn..)
powertripp is offline
post #13 of 15 (permalink) Old 04-27-2014, 08:30 PM Thread Starter
UPDATE!
HELP! I found these in the oil pan!!! I don't know what they are or where they came from!! Please help!
Edit: Their about 1/4 in diameter it looks like..
Also, one dot on each oil pump gear. I assume they line up next to each other. Correct??
post #14 of 15 (permalink) Old 05-01-2014, 03:03 AM Thread Starter
Piston ring job...
Done!
Took me 3 days.
Started right up!
I took it around the block twice just now to get it up to operating temp and noticed on the second time.. It started shifting gears a little roughly. Normal???
I'm taking it to work tomorrow so well see what happens.
Tons of pics tomorrow guys! Stay tuned!
post #15 of 15 (permalink) Old 05-01-2014, 04:32 PM
Dirty White Bull's Avatar
Congrats! Just a guess, but it may need to go through the complete drive cycles after disconnecting to 'relearn'.
Tyson
Dirty White Bull is offline
MAF testing trashtruck Maintenance and Repair 2 02-20-2016 03:20 PM
Engine pulls hard at idle, while in 'Drive' 1togofast Maintenance and Repair 2 03-10-2014 08:43 PM
Engine knock, rattle...any other possibilty? wallacereid Maintenance and Repair 16 04-23-2013 12:58 PM
