Won't kick down into passing gear - Taurus Car Club of America : Ford Taurus Forum
post #1 of 13 (permalink) Old 01-15-2014, 06:37 PM Thread Starter
I have a 2003 Sable with 89000 miles with trans with less than 5000 miles. when I drive in the mountains and step down to pass it will not go into passing gear and stay. It kicks in and out, and wont stay so I back off and drives fine. Otherwise the car drives and shifts normall. Any Ideas?
secondcrk is offline
post #2 of 13 (permalink) Old 01-15-2014, 06:45 PM
it'sthatcar's Avatar
Chapter: Northern
Are you driving it in Drive or Overdrive?
David
it'sthatcar is offline
post #3 of 13 (permalink) Old 01-15-2014, 06:49 PM
I experience this as well. I think that is how the PCM is programmed to control these transmissions. When going up a hill and I need to speed up, I usually let off the gas a bit, go from OD to D, and manually shift it that way. I have tried to apply throttle to trigger a downshift, but it won't even unlock the torque converter. The programming is very strange, sometimes even at lower speeds, if I apply throttle, the torque converter will lock up, though I expect it to remain unlocked. Maybe someone has more info, but this is my experience.
sable2000 is offline
post #4 of 13 (permalink) Old 01-15-2014, 07:09 PM
Chapter: Northern
I would be careful doing this, though. I was told you should be below a certain speed shifting between D and OD, but I don't remember where that cutoff lies. 60 mph?
David
post #5 of 13 (permalink) Old 01-15-2014, 08:41 PM Thread Starter
My trans only has 1-2 OD not 1-2-D-OD
post #6 of 13 (permalink) Old 01-15-2014, 08:42 PM
The White Falcon's Avatar
Year: 2010
Engine: 3.5L Cyclone V6
Your trans only has 1-D-OD, there is no 2nd gear option, be it floor or column shifter.
The White Falcon is offline
post #7 of 13 (permalink) Old 01-15-2014, 08:45 PM Thread Starter
1-2-OD Column shifter. Maybe I am wrong but the D has a circle around it anyway there is only 3 options
post #8 of 13 (permalink) Old 01-15-2014, 08:50 PM
Year: 2010
On a 2003? No, you don't. You have this:
post #9 of 13 (permalink) Old 01-15-2014, 09:08 PM
Now that you mention it, one issue I have with these cars is that you cannot select 2nd gear. There are some situations like in a city and traffic where 2nd gear would be desirable so the car doesn't shift all over at lower speeds. Plus, holding 2nd gear in these cars would allow for very high performance acceleration. I always thought the column shifter units had a button for OD, but I guess that is the G3 setup, where they had 1-2-OD, and the button to deactivate OD. I sort of wish I had the column shifter setup. The floor shifter is a waste of space. That crap was introduced to American cars and sold as being more "european" and "sporty" or something like that.
post #10 of 13 (permalink) Old 01-15-2014, 10:47 PM
Tom S's Avatar
Year: mult
Is the trans not under a warranty to where you can have them address this?
Tom S is offline
Transmission/Stumble issue please help. Pogosmoke Maintenance and Repair 4 09-15-2013 10:55 PM
Disable 1st gear on a 91 3.8 Tom S Maintenance and Repair 0 08-31-2013 09:36 PM
1998 Taurus need Vehicle Speed Sensor and VSS Gear Help Thegovernor Engine and Drivetrain 2 08-31-2013 01:44 PM
taller 4th gear and low MPG Architech Taurus and Sable General Discussion 31 07-22-2013 06:43 AM
Trans wont re-engage 4th gear under heavy acceleration Architech Maintenance and Repair 5 07-07-2013 09:57 AM
