2000 Sable running badly at low RPMs - Page 3 - Taurus Car Club of America : Ford Taurus Forum
post #21 of 30 (permalink) Old 05-03-2014, 12:45 PM Thread Starter
raybob95's Avatar
Still looking for an answer. Misfiring is pretty bad at idle (intermittently) and sometimes at low RPM when driving. Fuel mileage hasn't improved. The pending P1401 is gone.
I collected more data while it was misfiring right after I started it. This time I let it sit there and misfire for about minute while I collected data and the CEL finally came on with a P0301 code - Misfire Cylinder 1. After idling for a couple minutes, it started running fine, which is how it typically goes. At that point I turned it off for a few minutes, then turned it back on to collect data for the second file I attached, while it was misfiring again (about once per second on average).
Notice the LTFT on both sides is above 20% consistently. Also in the second file of data you'll notice the bank 2 STFT go above 20% for a few seconds as well, something I didn't notice before. I also noticed that the O2 sensor voltage for Bank 1 Sensor 1 and Bank 2 Sensor 1 was switching properly but was staying constant for Bank 1 Sensor 2 and Bank 2 Sensor 2. Could that be an issue?
Name:	Data Screen.jpg
ID:	100018   Click image for larger version
Name:	P0301 Freeze Frame.jpg
ID:	100026   Click image for larger version
ID:	100034   Click image for larger version
Name:	Pending P0301.jpg
Why have a sedan when you can have a wagon? Sometimes good deals for sedans come up
raybob95 is offline
post #22 of 30 (permalink) Old 05-03-2014, 12:58 PM
The White Falcon's Avatar
Year: 2010
Engine: 3.5L Cyclone V6
Have you ever replaced that O2 sensor? And you're sure you've got no vacuum leaks? Or a crack in the intake manifold?
The White Falcon is offline
post #23 of 30 (permalink) Old 05-03-2014, 01:24 PM Thread Starter
raybob95's Avatar
Don't know about the O2 sensors. It would be weird for them to fail in pairs in different banks though. Plus I was under the impression there was only 1 sensor per bank so I'm not sure if the sensor 2 numbers even mean anything.
We did multiple smoke tests and never found any leaks. We even sealed off the line to the HVAC system in case it was leaking. I haven't checked the intake manifold in depth but there's nothing obviously wrong with it. Someone suggested replacing the intake gaskets - is this enough of a possibility to just go ahead and do it or is there anything else I should consider first?
raybob95 is offline
post #24 of 30 (permalink) Old 05-03-2014, 01:24 PM
Year: 2010
Intake manifold gaskets would be a good way to start, both upper and lower. Especially if they've got 250,000 miles on them. They're not too expensive either.
post #25 of 30 (permalink) Old 05-15-2014, 11:23 AM
ddnguy's Avatar
On your software can you scroll all the way to the right and post the "Report" data. Like the Mode $06 data?
I have the same software and am having some minor misfires at idle only - does not sound as bad as yours. But I would like to see your Mode6 data and compare to mine.
I am suspecting a small air leak - but my LT fuel trims are not as high as yours.
I fail the $A1 $83 - Manufactured Defined Test. (I think I will start a new thread on that for some help) But pass all the other tests. I only see my misfire count go up on random cylinders at IDLE ONLY.
2004 Ford Taurus SES w\Vulcan Flex
ddnguy is offline
post #26 of 30 (permalink) Old 05-15-2014, 05:01 PM
sirtanon's Avatar
Ray, what software is that? Looks like it's running on an Android phone. Looks very useful.
sirtanon is offline
post #27 of 30 (permalink) Old 05-15-2014, 08:00 PM
viktor's Avatar
Originally Posted by raybob95 View Post
I'll be getting the cat replaced next week but I don't think that's what's causing all the symptoms. Poor fuel mileage and no power after lots of driving probably, but the misfiring under low RPM load and idle problems are probably something else.
I had a smoke test done today and they couldn't find any leaks anywhere, even with the HVAC system.
Any other ideas?
Sounds like Mrs. Viktor's '99 Duratec Sable was doing when the vacuum lines for the EGR valve and fuel pressure regulator was doing.
I don't know what they look like on the Vulcan, but on the Duratec, they're hard plastic lines, and they just broke with all the sub-zero temperatures we had this winter. It wasn't fun trying to fix them, either, because they kept breaking as I was attempting to patch the gaps with rubber vacuum hoses.
viktor is offline
post #28 of 30 (permalink) Old 05-15-2014, 08:21 PM
viktor, if that happens again, may try to snag a good complete vac. harness at a self service salvage yard. Those small hard red (fpr) and green (egr) lines do get brittle due to age/temp fluctuations.
post #29 of 30 (permalink) Old 05-15-2014, 08:22 PM
viktor's Avatar
That's the problem, though...any salvage yard replacements stand a good chance at being just as brittle as the ones currently on the car.
viktor is offline
post #30 of 30 (permalink) Old 05-15-2014, 08:28 PM
I've sourced 2-3 entire good ones in the past for various gen3 tecs for cheap.
Raybob's 2000 Sable Wagon raybob95 Taurus and Sable Project Log 174 10-18-2015 10:32 PM
2000 Sable GS running like garbage A Sharp Maintenance and Repair 16 10-30-2013 07:23 PM
Breeves002's 2000 Sable Sam Taurus and Sable Project Log 280 10-24-2013 10:33 AM
1996 Sable to a 2000 Sable johnwebb23 Taurus and Sable General Discussion 3 10-21-2013 06:00 PM
2000 sable stereo Sable476 Electronics, Security, Audio and Visual 8 04-02-2013 03:52 PM
You may post new threads
You may post replies
