Overdrive problems!!!! HELP PLEASE - Taurus Car Club of America : Ford Taurus Forum
post #1 of 4 (permalink) Old 03-26-2012, 03:10 PM Thread Starter
Thumbs down Overdrive problems!!!! HELP PLEASE
Hey guys i have a 1997 Taurus SE with a v6 Engine and its automatic. The car has a CEL for the catalytic converter . The problem is with my overdrive car runs fine in drive if i put in overdrive ill drive for about 2 minutes and the car will just stall in the middle of the street but if im in the highway and i switch to overdrive the car drives fine at high speeds???? so whats the deal with overdrive not working at low speeds? tranny fluid is full i checked it. could the BAD CAT be doing that ?? makes no sense help me out guys
willyebr is offline
post #2 of 4 (permalink) Old 03-27-2012, 05:46 AM
A plugged cat can cause stalling for sure. Usually it will run rough, and act sluggish too.
Sic semper tyrannous
Voltagedrop is offline
post #3 of 4 (permalink) Old 03-27-2012, 06:55 AM
JIMMER's Avatar
Yes, the cat can be the cause as there is more back pressure in D as opposed to OD. Replace the cat and the exhaust should flow fine.
JIMMER is offline
post #4 of 4 (permalink) Old 03-27-2012, 07:32 AM
Sooner, not later. Very hard on engine and valves to let this persist.
Good luck!!
downhill is offline
