Do You Guys Use Overdrive? - Page 8 - Taurus Car Club of America : Ford Taurus Forum
View Poll Results: What do you dive in?
Over Drive 133 87.50%
Drive 18 11.84%
2?? 0 0%
1???? 1 0.66%
Voters: 152. You may not vote on this poll
Closed Thread
post #71 of 76 (permalink) Old 06-20-2011, 08:55 PM
Urite!!!
sheila is online now
post #72 of 76 (permalink) Old 06-21-2011, 08:03 AM
SoNic67's Avatar
Model: Mercury Sable Wagon
And the offender is... machineop at post #56
SoNic67 is offline
post #73 of 76 (permalink) Old 06-21-2011, 05:05 PM
Will not use OD except freeway....
I started a thread about a problem with the 97 Taurus AX4N going into neutral every time i stopped at a light or stop sign.
Finally found out there is a weak piston inside the tranny that causes this problem. The replacement is a more sturdy design that any good transmission shop can tell you about.
Because the cost to repair the tranny, and because it shifts perfect in drive, but Not Overdrive, the Taurus will no longer be driven in OD except on the freeway. It shifts up through the gears fine in OD, just goes to neutral at stops.
If not for this problem of neutral @ stop I would still recommend always placing the shifter in OD unless i'm backing up.
I changed the fluid and filter, both were in good shape, and will continue to drive without OD until the tranny quits working.
kgrantkey is offline
post #74 of 76 (permalink) Old 08-18-2011, 03:34 PM
prismatic's Avatar
I drive in overdrive just about all the time, however I do use the normal drive extensively to engine break when coming to an exit or down a hill. It does a damn fine job of holding the car at 65 on a nice downgrade.
prismatic is offline
post #75 of 76 (permalink) Old 08-23-2011, 12:44 PM
Cheaper?
OK what is cheaper to repari, brakes, or trans.?
post #76 of 76 (permalink) Old 10-17-2013, 12:44 PM
The White Falcon's Avatar
Year: 2010
Engine: 3.5L Cyclone V6
Mods, please lock this topic.
The White Falcon is offline
Closed Thread
