Ax4n, Ax4s And Axoed Final Drive Ratios And Parts - Page 3 - Taurus Car Club of America : Ford Taurus Forum
post #21 of 29 (permalink) Old 03-03-2012, 01:17 PM
DEW
AX4N to AXOS Swap
Daughter wrecked her 01 Taurus U code, axos, have available an 00 Sable with Ucode, ax4n (Bad head gasket and tranny run dry) and want to do a cradle swap and junk the rest of the Taurus. I figure I have to swap PCM and engine bay wiring harness, but the connectors under the dash don't have the same pin patterns. Is the cabin wiring harness a standard item. or does that have to be swapped, too? What kind of trouble will I run into doing this, and what else needs to be done?
Sorry club members, haven't figured out how to start a new thread????
DEW is offline
post #22 of 29 (permalink) Old 03-16-2012, 08:32 PM
final drive?
Originally Posted by silvapain View Post
The gear ratio is the ratio of input revolutions to output revolutions. A 3.77 gear ratio means that the transmission shaft (drive gear) turns 3.77 revolutions for every revolution of the half-shafts (driven gear).
is this normal or final drive? Also, is "axle" ratio the same as "rearend"?
thanks!
jaecht83 is offline
post #23 of 29 (permalink) Old 03-16-2012, 08:40 PM
Zuljin's Avatar
thanks!
There's a list of what cars had which ratio. Also, kind of, but it's a chain inside the transmission instead of two gears in a rear diff.
Zuljin is offline
post #24 of 29 (permalink) Old 03-16-2012, 09:24 PM
thanks!
Issue that confuses it the OD is a ratio less than 1. So multiply the axle ration time the OD ratio to get combined.
OD likely 0.694 but depends on year and trans type.
http://www.ford-taurus.org/taurusinfo/Engine/Trans.php
post #25 of 29 (permalink) Old 10-24-2012, 02:03 PM
Originally Posted by shoz123 View Post
Yes better acceleration. My car runs about 2800 rpms at 70 mph. It does need a chip or tuning to make the TC happy.
So when you say tuning, can this be done at a dealer ?
Just to get the pcm to respond properly to the new inputs, will Ford do the programming for me ? Or do I need to look for someone who does custom work ?
FYI, newer trans installed and having some TC quirks.
Thanks !!
CraigS is offline
post #26 of 29 (permalink) Old 10-24-2012, 02:22 PM
Cool
Thanks !!
You will need somehting like a SCT Tuner. Ford wont know what to do.
92 White SHO
loudsho92 is offline
post #27 of 29 (permalink) Old 10-24-2012, 02:36 PM
Yeah I actually just got off the phone with the local dealer...said they don't get involved with any type of modifications like that. Generally just replace with new of the same.
I'll have to locate a tuner and someone who knows what to do with it ;-)
Thanks again !!
CraigS is offline
post #28 of 29 (permalink) Old 06-28-2013, 09:27 AM
AX Transmission.
I recently had a re-man transmission, and torque converter put in my '03 Taurus. According to the installation information the new transmission is listed as a 4F50N, replacing the AXOD. However, the oil pan on the new transmission is stamped AXAN. I know these transmissions are all of the same family, but I am curious, do you think it's a 4F50N, or is it a AXAN? Also, any ideas as to the final drive ratio? Thanks.
Andy in NY is offline
post #29 of 29 (permalink) Old 06-28-2013, 10:39 AM
4F50N replaced the AX4N in the early 2000s.
sheila is online now
