Check charging system warning pops up while AC or fan is running. - Taurus Car Club of America : Ford Taurus Forum
post #1 of 5 (permalink) Old 07-21-2019, 09:28 AM Thread Starter
Hi,
I have a 2006 Taurus. My compressor was drawing to much power and blowing a fuse, which also took out the idle regulator, stalling the car when it tried to drop down to idle. The compressor was replaced, which fixed the problem. Took it from Pittsburgh to NYC to Baltimore and back, using the AC the whole time, with no problem.
Now, all of a sudden, whenever I run the AC, after about 4 minutes, the "check charging system" warning pops up, and the battery light pops on. It stays on for about 20 seconds, and both warning and light disappear. This will continue to happen every 2-3 minutes or so until I shut the AC off. If I just run the fan, but no AC, same thing, but with longer time intervals. If I don't turn on the AC or fan, I never get the warning or the light.
I never had this specific problem before, but I did have to change the alternator a few years ago.
Any ideas?
Ralph Feldman is offline
post #2 of 5 (permalink) Old 07-21-2019, 10:03 AM
My question would be, " Does the light come on when you put the rear defroster on?" Maybe weak belt tensioner.
post #3 of 5 (permalink) Old 07-21-2019, 12:21 PM Thread Starter
Haven't had a chance to check it yet, but let me see if I understand your thinking. The rear defrost uses power but has no relation to the belt. So if it is the belt tensioner, then I shouldn't expect a charging problem when the rear defrost is on. Right?
The AC (and the fan?) both depend on the belt, so when I'm running the AC it puts extra stress on a weakened system. The alternator, which also runs of the belt, might be affected, then, when the AC is running. Is this correct? Because this sounds like a pretty good explanation for what I'm seeing.
post #4 of 5 (permalink) Old 07-21-2019, 12:42 PM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
The rear defroster draws a considerable amount of juice, making it a quick and dirty test to see if amp draw is the issue
It's SHO time!
jag1959 is offline
post #5 of 5 (permalink) Old 07-21-2019, 02:01 PM
You are correct somewhat. Both draw from alternator and could still mean a belt issue but the clutch on the AC draws a lot of powerbut only 1/3 of the defroster but at the same time the compressor is also adding a large belt loading at the exact time the alternator is being loaded. So the defroster would indicate more of a charging issue and AC more of a belt tension but not by much.
It shows a lot of your character in a positive manner that you are trying to figure the reason I suggested that.
check charging system goes on and off peskygnat Maintenance and Repair 3 08-05-2013 08:17 AM
computer problem or short in system??? peskygnat Maintenance and Repair 10 07-30-2013 12:25 AM
2007 Taurus Charging System DuB71 Maintenance and Repair 6 06-26-2013 04:52 PM
Charging system failure '01 flexfuel cmodena Maintenance and Repair 8 06-18-2013 11:22 PM
