P0300 & Lean Codes on both banks, Car now stalls out - Taurus Car Club of America : Ford Taurus Forum
post #1 of 7 (permalink) Old 07-17-2019, 08:00 PM Thread Starter
SonOfGib's Avatar
Year: 1999
tl;dr changed egr vacuum hose and put seafoam in tank, now car idles very rough and stalls out.
Alright so I am at a loss right now. Im just going to give the full story in hopes that someone thinks of something obvious.
Recently I noticed that my engine has been pinging (Its been in the triple digits recently and my commute has a lot of uphill driving. hills + ac = high load.) Since the car is about 20 years old I figured it wouldn't hurt to run some seafoam through the gas tank to help clean it out. So i dumped a full can into the fuel tank while it had about 6 gallons in it last night. Then in the morning, drove it 5 minutes to the gas station to fill it up and went to work. When I got in the car to go home and started it up, it pretty much immediately threw a P0171 and P0174, which didn't really surprise me since the car has had a rough idle since I bought it, and because I noticed the other day that one of the egr pressure feedback hoses had a hole in it.
When I got home, I figured I would scan it to see if I could figure out why the code was set, and sure enough my fuel trims were all in the 20%s (so about 40% Short Term + Long Term on both banks) Poked around for awhile and didn't really see anything other than that broken egr hose and decided to replace it.
Went to THE ZONE and got a new hose, replaced the old one and.....
As soon as I started the car it was making a loud hiss and stumbling all over the place, checked the codes and a P0300 had popped up. At this point I took off the new hose and replaced it with the old one but the issue is still there. Then I tried random things like unplugging the IAC and checking the rest of the hoses but nothing seems to change the misfire and stumbling.
Its pouring rain right now so I can't go and check the rest of the stuff I want, like the fuel pressure or the spark plugs, but I am extremely confused as to what happened here. I doubt the seafoam or the vacuum hose have anything to do with this but geez if itsn't a massive coincidence. Almsot forgot, I also added about 5 oz of seafoam to the crankcase as well, but again I doubt that has anything to do with it.
So .... thoughts?
SonOfGib is offline
post #2 of 7 (permalink) Old 07-17-2019, 11:13 PM
Year: 2002
Probably a pretty big vaccum leak somewhere, do a smoke test if possible.
Dappersworth is offline
post #3 of 7 (permalink) Old 07-18-2019, 06:11 AM
^^^^^ Agree 100%
post #4 of 7 (permalink) Old 07-18-2019, 03:33 PM Thread Starter
SonOfGib's Avatar
Year: 1999
Don't have a smoke machine. I tried spraying carb clean on a couple of spots but the idle never changed so that test didn't work. Still haven't gotten a chance to look again yet, but will be out working on it in the next hour or so.
SonOfGib is offline
post #5 of 7 (permalink) Old 07-18-2019, 04:43 PM Thread Starter
SonOfGib's Avatar
Year: 1999
Haven't found anything, fuel pressure and spark plugs were good. Car will run when you give it throttle but dies when you let off. I definitely am leaning towards big vacuum leak but just don't see where its from. Maybe I should go buy a vape lol.
SonOfGib is offline
post #6 of 7 (permalink) Old 07-18-2019, 07:09 PM Thread Starter
SonOfGib's Avatar
Year: 1999
Problem Located
Got it sorted out. As I figured it was something dumb I did.
I replaced my valve cover gaskets and upper intake manifold gaskets recently and when I did I had to move some vacuum lines so I could torch the egr valve fitting. Well, when I put that hose back on I apparently didn't route it right because it rubbed up against the egr tube and got a hole burned through it. Now I need some help identifying the hose so I can purchase a replacement.
It runs from the back driver side of the upper intake manifold all the way to the firewall on the passenger side of the car. Looks like it connects to the UIM pretty much under the IAC.
Thanks in advance (and retroactively) for help.
SonOfGib is offline
post #7 of 7 (permalink) Old 07-19-2019, 06:42 AM
Get some emission hose of the proper diameter from any parts store and replace it. It is just a hose.
bank 1 and 2 lean codes without issues Jvalentin92 Engine and Drivetrain 5 04-24-2016 09:23 PM
P0300 and P0316 Codes Oriolesaredabest Maintenance and Repair 12 02-04-2015 04:33 PM
CEL on, lean both banks and I may.. denis461 Maintenance and Repair 3 04-27-2014 07:32 PM
Large Evap Leak Detected & Both Banks are Lean? Flash619 Maintenance and Repair 8 04-13-2014 09:38 AM
You may post new threads
You may post replies
