A/c runs for a minute then shuts off. Help! - Taurus Car Club of America : Ford Taurus Forum
post #1 of 5 (permalink) Old 07-17-2019, 10:52 AM Thread Starter
Hi, I have a 2001 Taurus SE, 3.0L OHV. Turn on A/C, it runs for about one minute then shuts off, and I get nothing but hot air. I sure could use some help. I suspect the clutch may be the culprit.
39wolfy is offline
post #2 of 5 (permalink) Old 07-17-2019, 10:58 AM
You need to check pressures as mentioned in your introduction post but have you tried to add any refrigerant to try to fix issue. Overcharging could open the high pressure switch and shut the system down.
post #3 of 5 (permalink) Old 07-19-2019, 03:54 AM Thread Starter
Thanks for your answer
No, haven't tried to add refrigerant. One day the a/c worked fine, the next it didn't.
39wolfy is offline
post #4 of 5 (permalink) Old 08-01-2019, 08:01 AM
If it is low, you might want to make the first can of 134 with dye. cost a little more. but it will help you down the road find
the leak if you have one.
bob
soundu is offline
post #5 of 5 (permalink) Old 08-01-2019, 10:30 AM
As Automender stated, the first thing you need to do is check the low and high side pressures. Report back with the numbers.
A/c runs for a minute then shuts off. Help! 39wolfy Introduction Forum 4 07-16-2019 04:45 PM
Fuel Pump Runs after Ignition Off on Occasion hrtull Maintenance and Repair 8 04-23-2019 08:17 AM
engine runs rough when turning a/c or Heater on. rolinb Maintenance and Repair 3 08-23-2018 08:34 PM
Help! left turn signal shuts down engine. Brian in Tucson Engine and Drivetrain 11 05-03-2015 02:26 PM
Sable '04 DOHC unable to accelerate, runs rough, stumbles mysable2002 Maintenance and Repair 15 07-15-2014 12:56 AM
