97 Vulcan Taurus Starter Question.. - Taurus Car Club of America : Ford Taurus Forum
post #1 of 5 (permalink) Old Yesterday, 10:39 AM Thread Starter
Year: 1997
It's been a while, got starter issues, probably dead, can't seem to get a concrete answer so hopefully someone here can help, did the 97 vulcan starters still have that crappy spade connector on the selenoid of did they finally switch to the eyelet and bolt?
95Tbird is offline
post #2 of 5 (permalink) Old Yesterday, 08:35 PM
Play Nice or Don't Play
jag1959's Avatar
Engine: 3.4L Yamaha V8
IIRC Gen3's had ring terminals. Regardless if there is a spade connector on the replacement starter it is on a threaded terminal post and can be easily removed.
It's SHO time!
jag1959 is offline
post #3 of 5 (permalink) Old Yesterday, 09:57 PM
^+1. Easily converted. New starters usually come with a conversion kit.
post #4 of 5 (permalink) Old Today, 02:19 AM Thread Starter
Year: 1997
Thanks, I was just wondering if anyone knew for sure the 97 switched to eyelet with no spade, I keep seeing they stopped using the spade in 1996, I'm taking care of a sick relative so I'm trying to get this job done as fast as possible for another relative, I heard I only need 13mm 10mm and 8mm socket and wrenches for the job, along with the standard wire cutter heatsource for heatshrink tubing, screwdriver and maybe a breaker bar if there's any trouble, am I correct?
Someone mentioned locking nuts to keep the connections on the selonoid tight, does anyone have the dimensions for the nuts on the selenoid?
95Tbird is offline
post #5 of 5 (permalink) Old Today, 11:53 AM
I would put this as in the pic on every electric connections. It is made to keep down corrosion between different materials. Available at Lowes.
P0442 2003 Taurus SE 3.0L V6 Vulcan OHV 111k mfrey0118 Maintenance and Repair 39 01-08-2016 06:55 AM
1991 Ford Taurus 3.0 Need a starter mwylan Maintenance and Repair 17 10-24-2015 12:37 PM
Replacement Starter Question qman Maintenance and Repair 2 03-09-2015 07:40 AM
2004 Taurus Vulcan Misfires 007Taurus Maintenance and Repair 8 12-08-2013 09:06 PM
1999 Ford Taurus SE DOHC question about doors user9797 Maintenance and Repair 2 09-18-2013 01:41 AM
