2004 Taurus Water Pump - Taurus Car Club of America : Ford Taurus Forum
 3Likes
  • 1 Post By soulscourge
  • 2 Post By jpohlman
post #1 of 6 (permalink) Old 07-05-2019, 03:53 PM Thread Starter
My Taurus water pump shot. Direct drive from DOHV to pump with no idler pulley. Not sure how to replace pump. Do I leave one bolt loose to rotate the pump to act as a tension er?
dhovland is offline
post #2 of 6 (permalink) Old 07-05-2019, 05:43 PM
It uses a stretched belt.
post #3 of 6 (permalink) Old 07-05-2019, 07:16 PM
If one has the older years, you can put the stretch belt on and remove the tensioner. Cleans up the area and the belt is cheap. Not hard to put on at all. Done it and it works. I had a tensioner on '03 get noisy bearing. Got a stretch belt from the JY to be sure it fits.
post #4 of 6 (permalink) Old 07-06-2019, 05:09 PM
Model: Mercury Sable Wagon
Are you looking for directions on how to pull the water pump or just replace the belt. I've had mine off due to water circulation issues and can walk you through it. Mine has the belt tensioner on it, but removal is no different.
soulscourge is offline
post #5 of 6 (permalink) Old 07-11-2019, 06:49 AM
Putting the belt back on is easy.
Put the belt on the bottom pulley and pull the belt snug on to the back side of the upper pulley.
Secure it there with an 1/8" plastic cable tie, then turn the key just enough to turn the engine.
This pulls and seats the belt on the upper and the cable tie breaks on it's own as part of the process.
jpohlman is offline
post #6 of 6 (permalink) Old 07-12-2019, 06:19 AM
Replacing the pump itself is pretty straight forward. Remove the battery for much easier access. Biggest hassle is getting a few of the hoses off even with a spring clamp removal tool. Did the pump on my 05 Tec 2 years ago, and it took me around 3 hours doing it for the first time. WHile it is apart you may want to replace the thermostat as access is pretty easy.
I'm new here.How to judge the effectiveness of car water pump? Tiffany Yuan Introduction Forum 1 07-23-2018 09:52 AM
Engine swap 2004 Ford Taurus Moisesb55 Introduction Forum 1 05-11-2017 10:31 AM
Compatible Ford Taurus 2004 stock tires Sorainzo Aesthetics, Interior, Wheels and Tires 8 01-22-2014 09:28 AM
Q - water pump & steering pump paker Maintenance and Repair 5 10-02-2013 08:02 PM
1996 Taurus/Sable Fuel Pump Problems - pressure does not build up quickly or hold. MalibuMarkham Maintenance and Repair 7 08-28-2013 07:51 AM
